Question about mgtf clamp, manifold to cleaner. air cleaners. included with air
Bonnet cable has snapped on my tf, now cannot open bonnet an battery is flat
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Use lond screw driver and hit the bonnet lock from the gap created between bonnet and car
Posted on Nov 25, 2013
Hi my c2 bonnet cable has snapped.
Cut back the sheath around the inner release cable inside the car, and using a good pair of locking pliers (Vise Grips) pull the exposed cable.
Oct 13, 2016 | Citroen Cars & Trucks
If my cable to open the bonnet has snapped how do i open my bonnet
depends on where it snapped.
If it is accessible under the dash, clamp some vice-grips on it and pull.
If it is broken somewhere under the bonnet it gets a lot trickier as you'll need to find a way to trip the latch. Reply as a comment if we need to explore that.
Jul 07, 2016 | 2007 Ford Bantam 1.3i
How do I open the bonnet
has the cable snapped if it has its going to be a pig to do if possible and there is access you will have to get under the car and try to get at the bonnet cable pull it by wraping the cable around some pliers or the cable could of just come off the back of the bonnet release lever you will have to do a bit detecting to see where its snapped hopefully it will open if not only other way is to take out the front grill and use a screw driver to pop it open but you will destroy the grill getting at it
Apr 05, 2015 | 2005 Mercedes-Benz ML 270
Bonnet cable not working
REMOVE KIDNEY GRILL, GET A DENTAL PICK, TUG ON THE OPEN SPACE THAT EXPOSES THE CABLE RIGHT BEFORE IT GOES TO THE LATCH, TUG ON IT TO ACTIVATE THE LATCH AND IT WILL OPEN
Oct 05, 2014 | BMW X3 Series Cars & Trucks
Aston martin rapide battery has died and cant open the doors
When the battery goes flat on a rapide the windows are up. The doors are frameless so the windows are located in the seals in the door aperture. You cannot open the doors and you cannot open the boot. Look through the front grille towards the radiator with a torch and you will see the bonnet release cable outer sheath. If you pull the outer sheath it will put enough tension on the cable to release the bonnet catch. With the bonnet open you can charge the battery. Negative clip on the alternator casing and positive clip on the central charging stud.
Mar 04, 2012 | Cars & Trucks
This car is a 1.6 16v renault megane, the bonnet release lever does not open the bonnet, the cable appears to have stretched or snapped, how can i get in the bonnet? thanks
hi,
If the cable is snapped in your car, then get underneath the car.Try to reach the catch and flip it manually.If you are unable to reach it with bare hands, a bent metal hanger would help to do it.Now,open the bonnet. You can reach the parts in bonnet now. If you are uncomfortable or unable to do it, please call a "Repair person" in the nearest locality to help you.Have a nice day.Please rate my solution as helpful.
Feb 27, 2010 | Renault 181 Cars & Trucks
Hello, my battery has become flat but when I came
find bonnet catch and while someone pushes down on bonnet, pull the cable from behind the release lever (normally a black plastic covered wire) either the cable has siezed or the outer cable has sliped out of its retaining plate, if cable has broke, then access from under car with long rod to push lever over, again someone lightly pushing on bonnet will make it eaiser
Dec 06, 2009 | 2000 Volvo S40
Bonnet release cable has snapped how do i get into the engine bay to fit a new one?
it depends where the cable snapped. it it snapped near the opener just get a vice grip plier grip the cable and pull. the cable passes inside the left fender, just remove the fender liner and you can access it from there. if it snapped near the catch you need to remove the bumper and or grille
Jun 02, 2009 | 1994 BMW 3 Series
Bonnet cable snapped, need advice on how to open bonnet
Most of the time the cable snaps at the release handle. If you remove the handle and get the end of the cable, you can cut off the cable jacket and use needle nose pliers or vise grips to grab the cable and pull to release bonnet.
May 21, 2009 | 2001 Audi A4
How to open the bonnet of a Daewoo Matiz SE
Loo between both light in the long **** shape gap just below where the bonnet is. If you look to the right, you should see a black cable hanging down. If not the it has snapped away, but if you can. Here is what you can to to open the bonnet. Use a long pair of plires and gab the cable. When you have a good grip, pull the cable firmly to the right (passenger side light). This should open the bonnet. It has worked for me....
Hope this helps
Mar 19, 2009 | 2000 Daewoo Korando
mgtf clamp, manifold to cleaner. air cleaners. included with air Logo
115 people viewed this question
Top MG Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a MG Vehicle Part and Accessory Expert? Answer questions, earn points and help others
