Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
RF386PXE whirlpool oven, the oven and the stove top are not working, but clock is on
SOURCE: The oven will not light on my Whirlpool gas oven
Our whirpool glass top range elements all stopped working.The indicator lights on the back panel light up but the elements will not heat.We were using all four range top heating spots and the oven when the range top stopped working.Checked the circuit breaer and it was fine. I tried to locate a fuse for the range top but had no luck,range is about 7 years old
DAW983
Posted on Feb 15, 2010
SOURCE: My 3 year old barely used Whirlpool Gas Oven has
Just had a repairman here today March 31, 2010 for the same problem. $350 repair bill. There was a short in the gas valve that cause it to go bad and it also blew out the ignitaion computer board. Forget about replacing the ignitor. I already did and that was not the problem. So the qauestion for you is pay for the repair or buy a new stove.
Posted on Mar 31, 2010
  • 327 Answers
SOURCE: oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
Thanks
Posted on Jun 02, 2010
meztang
  • 112 Answers
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Posted on Jul 25, 2010
Whirlpool oven/stove with accubake. The cook top works with no problems the clock and display work with no problems. The oven does not work at all no bake no broil. Got it to work a couple time by...
Take a look at the oven ignitor,you might have two.The one at the top is the broiler ignitor.And the one at the bottom is your oven ignitor under your lower oven plate.
Feb 21, 2013 | Ovens
Have a whirlpool stove model # wbp88800. There is
F8Board failureReplace control board (also called ERC or clock).
May 14, 2011 | Whirlpool Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
The clock works and my stove still works; the touch buttons don't work for the oven. 2yrs old any ideas?
Either the touch pad or control board is out...need new one even if the clock works
Oct 25, 2009 | Whirlpool Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Kenmore smooth top stove has a code f1 on display oven. what is wrong?
Your electronic control board is bad. (clock).
It must be replaced.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Electric surge turned off the clock,oven but the stove top works
The clock and display are leds, right. If you can remove the panel where the board is and gain access to the back of it, look for a fuse, similar to a car fuse. The elements are controlled by manual independent switches, that's why they are working. If there is no fuse, or its still good, look for a burnt wire of some sort back there, as you said a power surge went through it.
Feb 19, 2008 | Ovens
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
21 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
