Question about Marklin Toys
Marklin 6032 Programmer
Looking for Instructions in English
I bought a marklin steam locomotive where the wheels are frozen up or not moving at all. Any help ? Ho can repair it. Thanks
If the wheels don't move even when you try to "slide" them with your fingers, the possible problem is with the motor brushes: with a pair of tweezers gently push the springs that hold the brushes (there is one cooper brush and a carbon brush, on the motor). Remove the brushes and replace them by new ones (available from any Marklin dealer). Notice that there are 2 brush models - for old motors and new motors (these ones use 2 carbon brushes instead). Hope this helps. Best!
Oct 08, 2013 | Walthers Marklin "Veolia Transport" Class...
Where can i find marklin train repair manual
check out this link www.marklin.com/tech/SignalManual.pdf
Apr 12, 2012 | Quinny Baby Gear
We need a station clock 2 inch diameter for a 1938 -- 1940 marklin station -- any ideas?
click on this Link, and at the lower portion of the page is "contact us" click that and send a message to Mark at the company itself http://www.marklin.com/
May 27, 2011 | Marklin Toys
I have three older marklin locomotives that are experiencing the same problem. As power is applied they start to chatter more and more loudly and will not run at full power. Sometimes they do this...
Probably the springs of the inverter unit are broken or too old. If you replace them by new Marklin springs, it shoud work. Notice that they must be the correct Marklin springs: any other springd probably won't work because their tension is not the correct one.
Best!
Jan 06, 2011 | Walthers Marklin "Veolia Transport" Class...
Hi I have an old Marklin HO M track from when I was younger but I cannot remember how to wire up the track,singals, turnouts,crane, etc. is there a book I can buy to help me out. Thanks.
You may want to try at this site: http://www.marklin.com/tech/ It is a tech page for Marklin products. I did not dig into the page but it looked like it may have something to help you.
Good luck.
Nov 10, 2010 | Toys
Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Aug 16, 2009 | Home
Toys Logo
63 people viewed this question
Top Marklin Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Marklin Toy Expert? Answer questions, earn points and help others
