Question about GE Refrigerators
Need a new water tank for Refrigerator GE RG2300NGN
Need a new water tank but don't know this part number
  • Katia Braune
    Katia Braune Nov 29, 2013
    Appliancepartspros.com didn't solve my problem.
    Top Expert:
  • GE Master
  • 12,962 Answers
Go to appliancepartspros.com
Posted on Nov 28, 2013
3 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Need your opinion on buying a new GE Profile refrigerator.
no dont do it GE is just bad news . if you must by ge make suer you buy the extended warr .and keep it current YOU WILL NEED IT ! ....... what one should buy? it does not matter , there all the same refrig inside ,just just STYLE you pick DONT FORGET EXTENDED SERVICE PLAN !
Posted on Jan 16, 2009
SOURCE: I have a model number and serial number for ge
I have a GE Refrigerator Model GTR16BBSERWW , Serial # ZH808092 I would like to know the cubic feet? Thank you. Marjorie Clay email redd_082739@yahoo.com
Posted on Jul 24, 2013
GE fridge, water dispenser putting out room temp water. Just connected it yesterday, sat all night, nobody used it, still not cold. model #TFX25CRY Inside temps are perfect. Please help!
Located in the back of the refrigerator is a plastic tank. This tank is the "Refrigerator water tank assembly". Water is stored in this tank and is cooled from the cool air of the refrigerator. It is located on the back wall. There may have been air prohibiting the filling until you cycled the dispenser allowing for the air to pass and the tank to fill.
It will take several hours for the water to cool.'
If the tank is in place (I'm very sure it is) the water must cool if the refrigerator is cool.
Hope this helps?
Jun 19, 2017 | GE Refrigerators
Water tank leaks
Turn the water off, find the leak and the model number of your refrigerator. Use the model number to search for a replacement water tank or water coil depending on what your model uses. If the water control valve does not leak you can turn the water back on until the water tank is replaced if the wires going to the water dispenser are disconnected. Just prepare for some water to spill once you begin removal of the water tank. This will allow ice to be made without causing water to pour out onto your floor while you wait for parts. It is really important to have the model number because without it the parts department will not be able to find one without it and internet parts view is not possible without the model number found around the fresh food section door frame. Have you located where the leak is? Is it something other that the water tank causing the leaking water?
There are many types of GE Monograms and different part numbers for different models. Can you post the model; number here on Fixya? Let me know if I can help you and I will be glad to give you the part number. Or click here and enter your model number=> Point and Click Appliance Repair I'm here if you need me, Thanks Sea Breeze
Sep 02, 2013 | GE Monogram Side by Side Refrigerator
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | General Electric Water Heaters
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
PART THAT SUPPORTS THE ICEMAKER BROKE OFF AND I NEED A REPLACEMENT. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Jul 07, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
How do I disconnect and reconnect the tubing for replacing a water tank on a GE refrigerator model #PSS25NGMB WWW?
generally the new tank will come with the hoses attached which you will need to run back to the valve. otherwise you cut the line and use a quick connect
Feb 05, 2010 | GE PSS25NGM Side by Side Refrigerator
I have a ge sig=de by side refrigerator and it has
Your model came with an electronic ice maker. If trays are empty tour on and fill with tap water. After it freezes if it cycles and dumps but does not refill with water the the problem will be the side of the water control valve on rear of the refrigerator that controls the water to ice maker. If the water freezes and does nothing then you may need to shop around for a new ice maker. Part number is WR30X10093 for the Ice Maker and WR57X10032 for the Water Control Valve. Let me know what you find or ask questions, Thanks, Sea Breeze
Dec 19, 2009 | GE Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
