Question about Vitamix 5000 Work Top Blender
Running vitamix at high speed engene smoke and rummbling sound then all speed controles opperating at 10 percent.
    New Friend:
Pls help, I need the spare part
Posted on Nov 25, 2013
2 Suggested Answers
ccaatteess
  • 10 Answers
SOURCE: my vitamixer's variable speed switch is stuck on
This problem sounds like failure of the Variable Speed Potentiometer component. Here is the most helpful Fixya article so far: http://www.fixya.com/support/t6032529-need_replace_speed_control
I have the same problem right now and don't want to pay ridiculously high prices for a small electronic component.
So far, this is as far as I've gotten in researching replacement parts:Vitamix Part #015955
Partstown sells #15955 for $23.39 on their website but I found out they charge $15 for shipping -- for a one-ounce piece of electronics. I won't pay to be ripped off on shipping so I won't buy one from Partstown until I've exhausted less-expensive suppliers. Here is the product at Partstown: http://www.partstown.com/vita_mix/vm15955
Another Fixya contributor, Robert Sadler, said he was going to try a generic potentiometer from Mouser.com. His descriptions are kind of vague for me. I'm not an electronics expert so I'm not very confident I can interperet his description:
"If you are comfortable with soldering, you can get a replacement part at Mouser.com. The pot is a 5k "slimline" made by Bourns, however looking inside the cover it looks like most pots would fit. I ordered one for a bit over $5 and will update when I get it with how it worked. You would just have to solder the existing wires to it." -Robert Sadler
I have no problem soldering the existing wires onto a new component but I don't really know what would be an appropriate potentiometer to buy as a replacement from an electronics supplier. In addition, Mouser's website seems to sell potentiometers only in bulk quantities of 5, 6, 12, or 45 items at a time. I just want one.
If anyone knows how to interpret Robert Sadler's comments, or has actually done this repair, please post below. I'm sure quite a few people would benefit from a high-quality repair at a low component cost.
Posted on Nov 19, 2011
Can the circuit board on the Vitamix be placed? I have a 5200 model which only runs on high. Changed the variable switch-no change to the speed.
Hello Melanie Richardson,
Looking around on the internet I did find parts houses
peddling parts...
But when I tried to go through the front door of VITAMIX... are interested in SERVICE (didn't seem all that WELCOMING to Do-it-
yourself OWNERS...
The short answer is yes ...
Vitamix 5200 Getting Started Machine
May 13, 2016 | Vitamix 5200 VariableSpeed Blender
Blender appears to be stuck on high. Today we changed the variable speed button blender still appears to be stuck on high.
The speed control usually is by electronics. The speed control switch will merely be telling the circuitry what speed is required but if the circuitry is faulty nothing will happen.
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
May 18, 2015 | Vitamix 5000 Work Top Blender
Why does my vitamix machine only have low and high, no variable dial?
You need to pay more money and buy the better model to get the speed control.
Jul 06, 2014 | Vitamix 5000 Work Top Blender
Vitamix 5000 Why does it run only on high ?
It very likely needs a new pot switch. That is the rotary one that varies the speed. Purchase through your local Vitamix service agent in your country.
Jun 05, 2014 | Vitamix 5000 Work Top Blender
Need to replace speed control
They are called a "Potentiometer" or Pot for short.
Variable Speed Control Switch
check here:
vitamix potentiometer
Feb 19, 2014 | Vitamix Blenders
When turning my Vitamix product on high it runs for about 45 seconds and then it shuts off. I then have to wait another 15 to 20 minutes before I can reuse the product.
It sounds like the motor is overheating, how long will it run with no beaker on it? If still 45 seconds I'd say new motor time. If it runs for 5 or 10 minutes then I would say replace the blade and bearing assembly in the beaker.
Aug 27, 2013 | Vitamix Blenders
Can't unscrew drive socket on vitamix super 5000 to replace it. The 5/64 hex wrench does not fit in. And another problem is that variable speed does not function. It is possible only slow or high speed.
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop. Speed control problem will likely involve replacing the control switch assembly.
Aug 25, 2013 | Vitamix 5000 Work Top Blender
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
Vitamix variable speed not smooth
Some models had a weakness with the variable resistance in the rotary switch but your description sounds more like the main PCB or even the motor both of which are very expensive parts to replace.
Nov 04, 2017 | Vitamix Blenders
Vitamix 5000 Work Top Blender Logo
207 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
ray gallant
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
