Question about Whirlpool MH1150XMQ Microwave Oven
Replacing handle on whirlpool microwave mh1150xmq-1
MicrowaveSvc
  • 9047 Answers
SOURCE: door handle
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I recommend that you do not remove the door or hinges to do the job because if it's not aligned exactly, you can have microwave leakage.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: door handle
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
scottowa
  • 87 Answers
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Posted on Mar 04, 2009
jsrock516
  • 5911 Answers
SOURCE: Replacing a whirlpool microwave door handle! got
To replace the door handle you need to access the door handle screws. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Nov 25, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The vent fan on my over the range Whirlpool
You either have a shorted exhaust fan thermostat or a shorted fan relay on the control circuit board.
While we regularly repair these controllers by mail for $39.95 postpaid with a one-year guarantee, or you can order a new control circuit board (part number) from the Pros here, we strongly suggest that you or someone you know check the exhaust fan thermostat first.
It should read "open" on a continuity (ohms) test. If it reads closed (shorted) it is bad and the fan will run all the time.
Or you can simply unplug the oven's power, disconnect one lead from the thermostat, tape it over to prevent shorting, then plug the oven back in. If the fan still comes on, the problem is on the board. If it does not, the thermostat is shorted.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Oct 18, 2011
Replace handle on whirlpool microwave
please see the video and use the common sense.
God bless you
Sep 09, 2012 | Whirlpool MH1150XMQ Microwave Oven
How do I remove/replace the plastic seal on the inside door of a MH1150XMQ-1?
The clear plastic cover is glued on. It can be removed with a heat gun to soften the glue. Then clean with Goof Off or WD40 and alcohol before installing the new one.
Eric
Jul 23, 2010 | Whirlpool MH1150XMQ Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Hi, I have a mh1150 whirlpool microwave. One
door doesnt typicaly come apart, door should be replaced. it is a barrier for harmful waves.
Oct 30, 2009 | Whirlpool MH1150XMQ Microwave Oven
How do I remove the old door frame and handle on the whirlpool microwave
To remove the handle yo need to pull off the inner plastic spacer (choke). The outer frame comes off by removing the screws on the edges.
Eric
Oct 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Handle-door
Look up your model number in the Whirlpool web site, they should have an online manual.
Jun 01, 2009 | Whirlpool MH1150XMQ Microwave Oven
Does not heat food
It could be 3 problems. 1. the part that spits out the microwaves needs replacement, door hinge switch is broken, or circuit board need replacement. First check with Whirlpool and see if it is under warranty still. Call a repair man. See www.repairclinic.com .
Mar 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
69 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
