Question about Heartland 3635B Dual Fuel (Electric and Gas) Kitchen Range
Hearthland ingnitors clicking
When I start the range top, the ignitors click and the burnurs ignite, but they just keep trying to ignite even if the burnet is lit... Please help
    New Friend:
  • 52 Answers
It sounds like an obvious faulty ignitor switch. The button you push to operate the piezo's is permanently on instead of make and break. If you can remove the switch you press, check that it is open circuit while it is not pressed. If here is a reading while it is not being pressed, then it needs replacing or repairing. Disconnect any mains connection before removing any covers. Electricity will kill you. Good luck
Posted on Nov 24, 2013
  • Steph M
    Steph M Nov 25, 2013
    I do not have an ingnitor switch ... it is all automatic... When I turn the gas knob, the spark is made automatic.. Could it be the ignitor automatic module ?
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Pilot keeps clicking even when burner operates;
unplug the range and wait 24 hours for the liquid to dry up. The clicking will stop when it is dry. The liquid has shorted the ignition switches causing the igniters to click.
Sep 26, 2009 | Tappan MGF500PBW Gas Kitchen Range
Gas will not light
yes quite simple if its easy to access the ignitor and housing area,on an electric either remove 2 wires depending on how connected and repl ingnitor and housing covers,all units are different but most have 120volt ignitors
Jul 16, 2009 | Garland H286 Gas Kitchen Range
Gas stove ignator makes
sounds like you got the electronic ignitor valves wet try blowing them out with air or don't use for a few hours
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore elite dual fuel range top ignitors clicking like lite mode is on, but it's not.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Feb 16, 2009 | Kenmore Kitchen Ranges
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Viking broil igniter does not glow, works ok on bake cycle
There are three separate igniters, one starts the broiler and the other two are bake ingnitors left and right.
So the bake circuits ignitors work and the broil doesn't
Replace the ignitor
The part number for all of them is PB040001
May 02, 2008 | Viking Kitchen Ranges
Firing Ingnitors
But when the top is closed, it starts clicking again.....it means that wire touching body of your range. Carefuly check wire connection and insullation, re-connect, or repair damaged wire insulation or replace damaged wire.
Aug 29, 2007 | Tappan TGF657 Gas Kitchen Range
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Heartland 3635B Dual Fuel (Electric and Gas) Kitchen Range Logo
117 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
