Question about Kenwood VR-616 Receiver
Is there a way to setup a microphone to a kenwood vr616 eq
I have a velodyne sub woofer needs amp power source I have a kenwood eq and a sony reciever trying to figure out how to hook it all up right
So, you don't have a powered Velodyne sub (with a built in amp?)
Without model numbers - I"ll guess that there are speaker in and out connections on the back of the sub.
You simply connect the left and right speaker wires from the receivers to the subwoofers input speaker wire connections.
Then connect your main speakers from the sub's Out (or "speaker"} connections so that the sub is in line with the speaker path.
Use the sub's crossover settings on the back till you hca a seamless blend of the sub to the speakers where it is hard to tell you have a sub other than you your music now has deeper bass.
Why do you need the Kenwood EQ? This is not a necessary piece as nobody really knows how to use it properly and it realy complicates how you use your system. Flashing lights look cool though, right?
If you really must complicate the operation of your system then connect the Tape output of your receiver to the tape input of the Kenwood EQ, Then connect the Tape output of the Kenwood EQ to the Tape input of your receiver - assuming your receiver even has tape ins and outs.
You can engage the Kenwood EQ by inserting it into the audio path when you select the appropriate Tape input as the source on your receiver.
Hope this helps.
May 31, 2014 | Audio Players & Recorders
Hook up kenwood ge-1100
2 stereo rca cables tape out to line in on eq, line out from eq to tape in on receiver. press tape monitor button to use eq, turn off tape monitor for direct. some receivers also have a dedicated I/o for eq, you just need to remove the jumpers and install in that loop (out to in on eq out from eq to in on rcvr}
Mar 16, 2014 | Kenwood Ge 1100 Graphic Equalizer
Low output on preamp
There are many "preamps" within this unit. Can you describe the exact setup and symptoms you are seeing this. Also describe the cabling ie, balanced... etc.
Jul 22, 2011 | Behringer Xenyx Xl2400 Premium 24 Input 4...
Cant hook up eq 2 kenwood vr 505 reciever
on the reciever connect patchcords from the tape out to the line in on the eq than line out from the eq to the tape in on the reciever --when you turn on the tape monitor button then the eq is engaged --enjoy
Sep 08, 2010 | Kenwood Audio Players & Recorders
I need a wiring diagram to connect up my kenwood amp, cd player, tuner and graphic equaliser
cd player(tape out)-------equalizer in------equalizer out-----amp line in.
tuner out-----to another line in in amp.
Nov 27, 2009 | Audio Players & Recorders
Connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
May 28, 2008 | Audio Players & Recorders
Clarion eqs746
more info would be nice...
what did you hook it up to?
Mar 23, 2008 | Clarion EQS746 Equalizer - 7-Band In-Dash...
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
15 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
