Question about Bosch Nexxt WTMC3321US Electric Dryer
Dryer not heating Bosch wtmc3321us
Dryer not heating
I have a Bosch WTMC3321 electric dryer, all of a sudden it does not work. You hit the start button and it clicks but the dryer does not spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
My 4 year old whirlpool dryer still work but smoke after 5mins of starting it. We cleaned the vents what should we do please help.
Sounds like it's getting to hot. If this is the case, the "high limit thermostat" is likely bad and need to be replaced.
Jan 26, 2011 | Bosch Nexxt WTMC3321US Electric Dryer
Clothes not drying all the way
Either the low heat limit switch (part is about $20) or if you have a long and/or clogged dryer vent, suspect the dryer element (part is about $100).
Jul 14, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer not drying
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WTMC3321US%2f07&ESHOPTYPE=S
Go to the link, page 4, item 405. this is a manual reset stat which may have been activated. Turn the power off, remove the back panel, locate the stat and there is a small button in the middle of it. If when you press it, it makes a definate click, the stat was activated and you have now reset it. There should now be heat if this was the only fault. Sounds simply but now you have to check why it was triggered...check the outlet hose is not too long or becoming kinked when unit is pushed back into position, check the discharge point on the other side of the wall is not congested with fluff build up or obstructed. Make sure when you run a cycle that you always let it finish the complete cycle as the last ten minutes of the cycle is a cool down and must be completed. Check that your washing machine is spinning effectively and the load is not going into the dryer too wet. Finally, ensure you are not overloading the dryer, adhere to the max load weight as per manufacturers guidlines.
Very much hope you solve the problem and save the cost of getting someone out, all the best and good luck.
Jul 12, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Makes a squeaking sound
had this once upon a time turned out to be bearing swelling as the cycle went on and generated a binding on it so thus came the squealing
Jan 28, 2010 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch 500 series dryer stuck on pause mode
things I would try:
remove the power from the dryer and let sit for a while. Plug back in when you feel it is time.
If that does not reset, I would take the cover of the board to see if the button is not stuck. (remove the top 1st, the the cover of the control board will come out)
Jun 05, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
My Bosch nexxt electric dryer won't turn on
Belt broke or came off. Replace or reset belt. Be sure to reset the switch that the tension arm activates when tension is lost.
Nov 04, 2008 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt WTMC3321US Electric Dryer Logo
23 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
