Question about Refrigerators
Ge rg2300ngp Need to replace the water tank but don't the part #
  • Katia Braune
    Katia Braune Nov 26, 2013
    I have a 10 years old GE Profile Arctica side by side refrigerator model # RG2300NGP and need to replace the water tank assembly. I noticed that there are various model numbers and I don't know which one fits my refrigerator.I need to know the water tank model number in order to buy it.
    Champion:
    Habit-Forming:
  • 279 Answers
Have you tried contacting GE service, they could probably tell you the correct part & probably sell one to you.
Posted on Dec 02, 2013
How to replace water tank on ge pfss6pkxcss refrigerator
Here is a link to the instructions per the Service Manual=> GE PFSS6PKWASS Water Tank Removal and Installation Instructions If you have questions I will be here to assist you, Thanks Sea Breeze
WR17X12468 Asm Water Tank and Here=> WR17X12468 Asm Water Tank
Jun 03, 2013 | Refrigerators
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
Jul 16, 2011 | General Electric GE SmartWater Household...
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | General Electric Water Heaters
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
I have a GG40T06/487-246 GE SmartWater Water Heater, it is about 10 years old and now there is leak on the position of the stem of the reset button connecting to the gas valve. Any suggestions to replace...
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Jul 19, 2010 | General Electric GE SmartWater Household...
Decreased water flow from dispenser GE GSS25WGTA refrigerator
This is usually caused by the water inlet valve not opening all the way or it got clogged up. The valve assembly will need to be replaced, don;t try cleaning it out it will likely cause a clog further up the tube. They are usually pretty inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/referwaterinlet.html
Jun 23, 2010 | GE Refrigerators
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Water won't flow from GE Smart Water under-sink RO water filter
Disconnect the water pressure tank making sure the end the line hooks up to is open. The tank should be relatively light, and if you shake it you should not hear any water. If you hear water in it, or it feels heavy, that means the bladder inside the tank has failed. Replace the tank with a new one, and set the pressure on the bicycle type valve at 8 PSI before you connect the tank up to the water line.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Need install instructions to replace water tank
there is no online instructions that i am aware of.
Jun 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
