Question about Frontgate Nespresso Pixie Brown Machine - Electric Titan - Frontgate
A capsule is jammed and the locking bar won't lift to eject the spent capsule. Should I force it?
  • Jim Theel
    Jim Theel Nov 26, 2013
    I removed the water reservoir and placed the appliance over the edge of the counter. Holding it securely, I forced the locking bar and was able to eject the jammed and badly distorted capsule.
My nespresso u machine capsule slot wont open
Turn the machine off and unplug it from the wall for 10 seconds. It may just have a capsule stuck inside. Doing this will get the machine to eject any capsules when it is turned back on.
Feb 03, 2013 | Nespresso C100B Essenza Single-Serve...
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Head won't lift without force. The head lock is in the Unlock position but it doesn't lift up easily. I have to stand behind the unit and use a lot of force to pull it up. It was fine one minute...
Presuming all looks OK near pivot & lock mechinism? can you see the locking hook in rear of mixer head at the hinge area directly behind lock lever, and is it nested in the slot on the base, or is it jamming up outside the stand and scratching it up?
There is a flat-head height adjust screw to control clearance between spatula and bottom of bowl visible from head-back position- leave it alone. There is a headless set screw visible when mixer is upside down to hold the pivot pin secure. This must be loostened with long-shaft flat screwdriver to remove the pivot pin for head removal if necessary ---avoid removing the pin if possible.
Is the hinge stuck with film of sticky sugar, milk-glue residue, ot the like? That is most common cause, distant second is the lock mechinism alignment (very rare)
Its important to keep head from wobbling side-to-side in use, so dont file or sand anything
Can telephone 609 213 2222 if necessary no charge for my talk.
Oct 16, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
The screen says "empty dregdrawer".
  1. Remove the drip tray (it just lifts off)
  2. Pull on the bottom section, this is a drawer which contains the spent capsules.
  3. Empty the drawer.
  4. Replace the drawer and the drip tray.
This video shows how it's done around 6:55: http://www.youtube.com/watch?v=QnJwgnbfmoQ
Feb 28, 2011 | Lavazza 2210
My cd rom will not open what can i do
  1. Software can lock the CD drive preventing you from ejecting. If this is the problem, turn off the machine, turn on, when the DELL screen flashes, push the eject button several times and the CD will eject.
  2. If that doesn't work, look for a small hole the size of a paper clip and gently push a paper clip into it. When you meet resistance, the drawer will start to open. You can then pull it open carefully. The computer can be off when you try this.
  3. If neither work, then you might have a jammed CD, i.e. incorrectly inserted. You can try to force the drawer open with your fingers but don't use so much force you strip the plastic gears.
Aug 14, 2010 | Dell Dimension C521 PC Desktop
I can't open my DVD-Rom drive and it doesn't read the information in my CD drive? It's an HP Media Center PCm7334m, computer.
Aug 14, 2010 | HP Pavilion Media Center TV m7330n...
My Dell laptop #S1555 won't eject a CD?
Aug 14, 2010 | Dell Studio 15 Laptop
Fault f72
this is usually due to the hinged part of the capsule plate failing to return to the normal resting position after ejecting the first capsule. You can resolve this problem by occasionally pulling the capsule plate out of the unit and running it through the dishwasher. You can also scrub it with a toothbrush under hot soapy water. Coffee stains build up on the mechanism preventing the plate from dropping to the rested position. The second capsule hits this and jams rather than riding the ramp into the puncture plate.
Feb 21, 2010 | Miele CVA2650 Stainless Steel Espresso...
Frontgate Nespresso Pixie Brown Machine - Electric Titan - Frontgate Logo
Top Frontgate Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Frontgate Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
