Question about LG DLE2532W Electric Dryer
Problem with LG electric dryer DLE2532W, approx 10yrs old.
For a while, sometimes instead of starting, the dryer will make a humming sound like it's trying to start. Sometimes it would catch on its own, but now it needs me to rotate the drum to the right in order to start every time. I read one solution for a different model that suggested the motor capacitor, but I can't find that part on the parts list in the repair manual. What needs replacing? The belt seems fine, and all lint has been cleaned from ducts, lint trap and front cover of unit. I am a novice, should I just call the repair service?
  • LG Master
  • 8,220 Answers
When you turn it yourself is it real stiff and hard to turn? It should not be. You might need a wheel or maybe a glide. I have the manual
Posted on Nov 24, 2013
  • 1 more comment
  • Dan Webster
    Dan Webster Nov 24, 2013
    check that drum for cracks they had a lot of bad drums
  • Suzanne Schendel Kirk
    Suzanne Schendel Kirk Nov 24, 2013
    It is stiff and hard to turn. I didn't see any cracks. Is the glide or wheel a relatively easy fix? Do I need to get into it from the back to check these things? I found the service manual online.
  • Dan Webster
    Dan Webster Nov 25, 2013
    You gotta take the top off first the open the ddor and remove 2 screws remove some screws up top holding the fron panel on the unplug the door switch, then you can inspect the parts the drum rides on and the wheels.
4 Suggested Answers
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
SearsTechToo
  • 261 Answers
Sounds like the starter winding is out.
Posted on Sep 19, 2008
  • 574 Answers
SOURCE: LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Posted on Aug 25, 2009
DLE2532W LG dryer, dryer won't start
new controls
not plugged in
not switched on
Aug 09, 2013 | LG DLE2532W Electric Dryer
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Lg dryer Dle2532w electric humming will not start till i manualy turn drum
Possibly the belt is loose and not grabbing on the drum or motor properly..I had a humming noise, which come to find out was the motor turning but the belt was not.
Jan 31, 2012 | Dryers
Bad vibrations
you will need to remove the top panel and look at the belt and tensioner pulley.
when the bearing in this pulley dries up it will make this horrible sound and also stretches the belt too
Jun 08, 2010 | LG DLE2532W Electric Dryer
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
Dryer has power but drum want turn
check to make sure that nothing is stuck in the blower wheel if nothing is caught then you need a new motor
Dec 19, 2008 | LG DLE2532W Electric Dryer
Removing LG dryer top plate
If your going to do this..... UNPLUG THE UNIT FIRST OR TURN OFF THE POWER.
You can use a 1" paint scraper, it will do the trick, but get one that is strong.
Why is your thermostat blowing though? Do you have a venting problem that may be causing it?
Sgt 48
May 26, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
81 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
