Question about Thermador Kitchen Ranges
Indicator light comes (ON) won't heat beyond 100 degrees,model RDDS30
The oven heats to 100 degrees then ON light comes on-will not heat over 100
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
May need new Hot Surface igniter.
Posted on Dec 29, 2013
4 Suggested Answers
  • 213 Answers
SOURCE: ge oven...gas....not heating right
there is an ignitor bar that has to operate properly to open the gas saftey valve. the ignitor can glow but be weak so it wont open the gas valve. replace ignitor to slove problem
Posted on Nov 20, 2007
  • 9 Answers
SOURCE: the oven will not heat past 100 degrees on the
repace the oven sensor
Posted on Jul 21, 2010
  • 2183 Answers
SOURCE: Our GE profile oven model
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
Posted on May 15, 2011
Kenmore elite electric oven model 790.48033800 stopped heating after running a cleaning cycle. Fan in oven runs, display remains at 100 degrees.
You are basically saying it cannot correctly read the temperature and does not heat the oven any more?
I am thinking this sounds far more like the thermostat that has failed as it reads the temperature, and also regulates the heater on/off depending on what setting you have selected. Easily replaced but will almost certainly require removing the oven from the cabinet (why won't it come out? Usually there are 2 or 3 screws vertically up each side viewable when oven door is open; remove them and slide the whole oven forward).
Good luck
david
Dec 15, 2013 | Kenmore Washing Machines
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
GENE
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 15, 2010 | Ovens
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Taking a long time to heat up
sound like you may have a burnt fuse causing to run on half voltage check your fuses thanks from gilles
Mar 14, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Maytag MER5870 Electric Kitchen Range
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
Sep 22, 2008 | Maytag MER5870 Electric Kitchen Range
Neff b1432 electric oven not
I have the same problem too but mine doesn't produce any heat at all. When it's switched on, the air that comes out of it is cool. How could i fix this? Do i have to replace a part or could it be an electrical fault?
May 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
111 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
