Question about Honeywell Programmable Thermostat Heater
Replacing a White-Rodgers 1F56-301 with a Honeywell RTH22181039. The WR is so old the wires are not labeled and not sure how to connect.
    Master:
  • 571 Answers
That is something that someone needs to lay eyes on. You never know how one will color code the wires @ the furnace...let alone through the wall. Someone will have to ohm out the wires.
Posted on Dec 12, 2013
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
Need owner manual for 1f82-0261 white-rodgers
The owner's manual for the 1f82-0261 heat pump thermostat is available here: http://www.honeywell-thermostat.com/honeywell/1f82-0261-thermostat.htm . Look for the link to Additional product information.
The direct link is http://www.honeywell-thermostat.com/manuals/1F82-0261Manual.pdf . The operation section starts on page 6. A second site with the manual is http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-7022.pdf .
I hope this helps.
Jun 27, 2011 | Emerson Heating & Cooling
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
Lookin for wiring instruction in replacing old buld typr Weathertron 3AAT86B!D1 with wiring as follow: Y-Yellow T-Brown B-Blue R-Pink W-White G-Green O-Orange X2-Black to be replace with White-Rodgers...
The best thing to do here is to verify the function of each wire. You may need to call the manufacturer of the old thermostat to have that information. Then cross that with the WR stat. If have difficulty you may call hometechline 18002842925.
Nov 26, 2009 | White Rodgers White-Rodgers 1F85RF-275...
I'm replacing my old thermostat with a honeywell
usually you should have 4 or 5 wires....if you have AC then this wire should be Y if not was it connected at all before?...Heating requires only R&W
Oct 24, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
124 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
