Evopower GG1500 Petrol Generator - Televison & Video
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Wolf 5000kva generator
Locate where the choke lever is for your generator (under the petrol tank), you ought to notice a star headed shaped screw connected to the governor shaft (if you bend and look closely further beyond the choke lever; still under the petrol tank) which is linked to the carburettor housing/assembly. You need to increase/turn clockwise (using a star screwdriver) on this screw.
Your generator engine sound will change/high a bit because the engine speed will increase.
Reconnect your 1800w chop saw (load) and see if your generator can "effortlessly" accommodate it without shutting down otherwise, increae the turns on this adjustment screw attached to the governor shaft till your generator operates/stabilizes with the load (1800w) connected
Oct 05, 2017 | Wolf Manufacturing Electrical Supplies
Why does my yamaha generator ef3000ise petrol run out of the air filter when it is stopped but it will run fine otherwise
Carb float is stuck open. Take the carburator apart and clean it, blow it out with compressed air. put it back together see if that works
Sep 29, 2012 | Yamaha EF3000iSE Inverter Generator
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Cannon BGE 3000 petrol generator runs for about 10-20 minutes then cuts out. Just occasionally it doesn't quite cut out, but will get going again without me having to start it.
hi i have a BGE 3000 petrol generator it was working 1 min and stop the next it runs well but there is no power going to the panel on the front any help? thanks
Mar 17, 2010 | Cannon Electrical Supplies
Shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
Jun 08, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Ihave a g900 clarke generator that runs perfect,smells of petrol
Hi i have the same unit, i believe that this is just after fumes that actually smell very much like petrol. As this happens to mine as well and the cap is a very tight seal. Its very much like the smell of an old petrol lawn mower.
Do you know which way round the 240v plugs go.... for instance, which pin is positive (live) and which pin is ment to be negitive (neutral).
As you can put the plug in either way it just seems wrong??
POST SOLUTION HERE THANX
Mar 31, 2009 | Electrical Supplies
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
