Question about Canon EOS 1100D / Rebel T3 Digital Camera
Won't take picture
The camera is in AF but it won't take a picture. Exp SIK comes up on the screen.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Check the manual. In the troubleshooting section, it should explain the error codes.
Posted on Nov 26, 2013
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Flahing box on my Rebel T3i display that reads [exp.sim] It won't let me take pictures??? What to do?
Dear BuzzWhitey,
I assume that you're stressed out after witnessing this problem. However, I recommend that you don't worry much about it.
I can explain it in further detail. But, it would be best to refer to your manual. This isn't a problem. It's merely fixing the settings which will allow you to use this wonderful camera.
Please refer to Page number 126 in the handbook. All the best.
Happy Snapping,
Rebel K
Feb 21, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Kodakeasy share v1233, Some times when I go to take a picture the screen goes pink and there are lines through the screen, and a Captial AF in brown comes up. It does not do this all the time, but it
Hello Cathy, The "AF" means auto focus, The pink screen and the lines are a camera fault, you are going to need the camera checked to see what the internal problem is, it is not something that you are doing wrong, it is the camera.
Best Regards, Russell
Dec 13, 2012 | Kodak Easyshare V1233 12.1MP Digital...
Nikon D90 Self-Timer does not work when flash is engaged.
The answer to your question can be found at...
This website
All but the very best flashes can not recycle atthat flash rate. For burst mode, you probably want to use focus modeAF-C or AF-A.
Morris
Page 73 in the manual; If the flash fires in L or H mode (pg. 65), only one picture will be taken each time the
shutter-release button is pressed. The shutterrelease may be briefly disabled to protect the flash after it has beenused for several consecutive shots. The flash can be used again after ashort pause.
The flash can take several seconds to recharge andduring that time the shutter is disabled. NR will also reduce thenumber of frames per second that you can take, and of course yourshutter speed has to be fast enough to allow for 4.5 fps.
In AF-S the shutter won’t fire unless the camera has achieved an in-focus state and the focus is locked.
In AF-C the camera continually focuses, but that isnot the same thing as being in focus. As you move the camera or yoursubject moves, the in focus state will come and go, but the camera willattempt to continuously re-focus. BUT, the shutter will fire even ifwhen the AF system has lost the in-focus state and the picture is outof focus.
In the D90 manual it indicates that the AF-A modewill only fire when the green in-focus light is on, just like in AF-S.The problem is that you probably won’t get 4.5 fps unless both thecamera and the subject are stationary and no time is lost between shotswhile the camera re-focuses.
Brooks
http://bmiddleton.smugmug.com/
Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
AF! error
my camera comes on when I go to take a picture it comes up with !AF on the screen and will not take the picture has been working ok so its something really silly that I cannot solve.
thanking you
Sep 09, 2008 | Fuji FinePix A303 Digital Camera
What is AF on my camera?
A bit more detail would be helpful to diagnose your specific problem: what mode is the camera in, does it do it all the time or only in certain situations.
There are a few situations when the autofocus does not do well: focus too close to the subject, or in a very low light situation, or the subject is gray. Check that you are not affected by any of these.
Otherwise, try to find if there is something wrong with your camera: find someone else with the same camera (or one in a store display), and see if following the same steps gives you the same result.
Dec 27, 2007 | Cameras
Sad photographer
Sounds like you need to get your camera fixed by Nikon.
However, you say the auto focus stopped working, you didn't switch to a lens that uses a mechanical focus linkage do you? The D40 only supports lenses with AF-S or AF-I type autofocus drives. AF-D and AF-G types without AF-S or AF-I don't autofocus.
Also, check that the A/M switch on the lens is in the correct position.
Manual focusing is quite difficult to do accurately with an AF camera. The screen inside the camera is not optimized for this. If you are sure you are focusing accurately but the pictures you take are still out of focus, the mirror may need adjusting. I can provide further info on this if you require, but if you're within warranty, i'd recommend that route first.
Nov 19, 2007 | Nikon D40x Digital Camera
Af and flash button flash continuously when camera switched on
How old is the camera? Take a new approach to Nikon. But costs are about right- it is no joke.
Aug 10, 2007 | Nikon Coolpix 5600 Digital Camera
AF problem
Jangles, I am having the exact same problem. Have you found a fix ?
Aug 13, 2006 | Nikon Coolpix 5600 Digital Camera
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Nov 11, 2005 | Nikon F4s 35mm SLR Camera
Canon EOS 1100D / Rebel T3 Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
