Question about Dell XPS Computers & Internet
Dell xps 15 (L521x) replace LCD screen
Can somebody tell me how to remove (replace) the LCD screen of the XPS15 (L521x) which has the new gorilla glass.
    Sergeant:
  • Dell Expert
  • 352 Answers
Hi Roger Urscheler,
You may refer the below link for manual of Dell XPS L521X to get help on replacing LCD screen:
http://dell.to/1dJjLFO
However, if this doesn't help I would suggest you to contact the Dell out of warranty team on 18002884410 (U.S only). They can help you further with repairs only.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Posted on Dec 01, 2013
octeks
  • 52 Answers
SOURCE: LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
Posted on May 05, 2009
  • 32 Answers
SOURCE: my dell xps m1530 lcd panel problem,the lights are
there is something wrong with the graphics. or you can look cheapest aion gold and buy aion kinah
Posted on Dec 15, 2009
c_robertson
  • 123 Answers
SOURCE: dell xps m1330 laptop
  • First purchase/get a usb mouse and plug it in. It may take a few minutes for it to start working. It will have to install the driver first.
  • This will allow you to get around in windows.
  • Now open your device manager
Windows xp – Start button>run> type devmgmt.msc
Vista/Windows 7 – start button> in the search box type devmgmt.msc
  • Look for a ! ony any device and right click, select update driver
  • If you do not see a ! on any device, your touchpad may simply be bad and need replaced.
  • In ebay search for; manufacturer, model, touchpad
replacement of the touchpad is a whole different set of instructions.
Posted on Jan 24, 2010
  • 261 Answers
SOURCE: Dell xps laptop lcd screen black
hi most of xps has this problem the graphic chip is burnt and some times work with reflow
its better that the chip chang
Posted on Nov 13, 2011
In MS Word and Excel, Ctrl+Home and Ctrl+End keyboard shortcuts do not work
Tollie Botha,
Try the informational steps below to resolve your issue.
In Word, go to Tools > Options > General and uncheck both options that mention WordPerfect.
In Excel, go to Tools > Options > Transition and uncheck the "Transition navigation" box.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Tollie, click the link below and check out the google searches to resolve this issue.
http://bit.ly/1jVAdHh
Thank You,
Dell-Jesse L
Oct 21, 2015 | Dell XPS 15 L521X
Where can I found a download for MATSHITA DVDRWBD UJ167 SCSI CdRom Device
Go to the laptop company site and check for downloads
Sep 28, 2014 | Dell XPS 15 L521X
I have a 'top of the range' Dell XPS 15 (L521x) which I have owned for only a year and it's screen has died again.
from what i have just read as far as dell reviews, this is the norm ,i also have had friends tell me of problem like yours, and what they had to end up doing, my suggestion since dell has a bad rap with all of their products is go to another brand, asus is good, hp also, make sure if you can to take all your important data and back it up to cd or dvd disk so you can put in new laptop
Aug 13, 2014 | Computers & Internet
How to remove keyboard on dell xps L521X
Here's the repair manual which includes instructions on removing and replacing the keyboard. Grab a t5 screwdriver (or bit for your drill) from the hardware store if you don't have one. You'll need it to get into the back panel. Good luck!
https://www.hansonsgeeks.com/PDF/Dell/Owner%20Manual%20xps-L521x.pdf
May 29, 2014 | Microwave Ovens
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Hi My Dell XPS 1530 Screen remains black at startup
hi
if your Laptop is on and your not getting screen the you have to do two thing
1 remove RAM from the motherboard
2 remove CIMOS battery from the motherboard for 10 to 15 mints
then re fix hope fully your laptop will work
Aug 02, 2010 | Dell XPS M1530 Laptop
Dell XPS M1330 PC problems when turning on
Faulty LCD Inverters were causing similar power problems on dell laptops. if you know how you can remove the lcd screen and try run it on an external monitor, if it works, replace the LCD Inverter.
Dec 23, 2008 | Dell XPS M1330 Notebook
Computers & Internet Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
