Question about Cooktops
Cata washing machine wfh 60 manuals - Cooktops
Not working
I hope that I am wrong but I think that you will need this part.
Range electronic o...PART NUMBER: 74011719
Substitution: 8507P226-60
Manuals, parts list and diagrams are available here.
http://www.searspartsdirect.com/partsdirect/part-model/Jes8850bas?page=1
Searching Model For Search Your Way Jes8850bas 2
Aug 30, 2014 | Jenn-Air Jes8850bas Stainless Steel...
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Download users instructions for ceramic t/ch hog model no. ECL90T
My search shows that the ECL90T hob is a product of an India-based company, Cata. Visiting their website reveals no direct link for Support or downloadable manuals. However, there is a link to contact them through email which I believe is your best bet. Here is the link:
http://www.cataindia.com/ContactUs.php
Also, I found a UK-based site where you can purchase parts. Contacting them may also yield a user manual:
http://www.myspareparts.co.uk/cata/Cata-ECL90T-Long-Ceramic-Hob
Feb 11, 2012 | Cooktops
Operating instructions for ECL90T
My Spare Parts UK has the manual on their downloads site: http://www.myspareparts.co.uk/cata/download-user-manuals.htm . The direct link is http://www.myspareparts.co.uk/UserFiles/file/ECL90T-Instruction-Manual.pdf . Scroll to page 12 for the English version of the manual.
I hope this helps.
Kenmore 110-44182400 washer fills, agitates but will not empty
Hello there and thank you for choosing fixya
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Apr 10, 2011 | Kenmore 44182 / 44813 / 44814 / 44819 37...
When the knob is turned to lowest - the flame goes out. I've cleaned and washed per the mfr instructions.
Hello, thank you for your post. It sounds like you have done some preventive maintenance which is good. Your next step is to change out that bad valve. On some models you can adjust the flame but only reducing the gas supply. In this case you need to replace the valve because it is defective.
Look at this link depending on which knob is effected item#6,3,5, or 5
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0106083-00002.png
If your going to changed out that valve make sure the gas supply is turned off and electric is unplugged. Each part are priced around $60 - $100 but shop around for the best price.
*After changing a gas valve always check for gas leaks with a leak detector, test and retest.
Happy Holidays!
Please rate me "4 thumbs" if I was helpful.
Dec 19, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
What are the dimensions for the JED8430??
The top dimensions are 29 3/4" x 22" and the cut out needs to be 28 7/8" x 21 1/8" if the need the install manual you can get on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P419-60.pdf
Good Luck and please Rate 4 thumbs for the free answer
Jun 06, 2010 | Jenn-Air JED8430 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Cooktops Logo
20 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
