Question about HP EliteBook 8560w Mobile Workstation
When i tun on only fan runs, nothing appears on the screen
Booting issue
  • 46 Answers
Try to remove your battery and hold the power button for about 45-60 seconds. Then put your battery back in, and try to reboot. This may not help, I'm just eliminating possibilities hoping your motherboard isn't at fault.
Posted on Nov 27, 2013
  • Kris P Cream
    Kris P Cream Nov 27, 2013
    CORRECTION: Connect your charger and DO NOT put your battery back in quite yet. If your computer starts, then you're good to go. Place your battery back into it's housing and continue as planned. If this does not work, Chances are you need a new monitor.
  • Kris P Cream
    Even Better! Check out this link I found. It covers what I was trying to tell you and actually gives you further instructions so that you may manually troubleshoot your notebook on your own.http://h20566.www2.hp.com/portal/site/hp...
PC not booting up.
if its windows after you push the power button keep pushing f8 till you see a boot menu / choose boot in safe mode then you can use system restore /sounds like a bad driver/ loose processor/bad fan improper cooling could be the graphics card itself
Aug 02, 2017 | ASUS P5N73-AM Motherboard
Screen is black cursor moves , but nothing appears. just changed fan
  1. Have you made any changes to the computer prior to this issue?
The issue you're facing could be related to drivers and could be resolved by updating the display drivers.
2. To confirm this run your system low resolution mode.
  • Press and hold the F8 key as your computer starts.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Enable low-resolution video, and then press Enter.
If the problem doesn't reappear in low-resolution mode, then the issue is driver related. Then you download display driver from your graphics card vendor site.
Thank You For Using FIXYA
Feb 20, 2011 | HP Compaq Presario SR5050NX PC Desktop
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
I have a Powerbook G3. Gets power but does not boot up.
It may not be a fan, it may be the cd drive spinning up. Is there a cd in it?
Jul 18, 2009 | Apple PowerBook G3 266Mhz w/ 14.1" Screen...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
My Screen is blank and fan continuously runs.
your computer is not posting that is why you do not hear a beep. This can happen for 1 of 10000000 reasons but I would start with checking the RAM then all the other hardware to find a loose connection/dead hardware.
May 28, 2009 | Compaq (203966-001) Motherboard
Acer Aspire 5610 boot issue
The Video Chip or VIdeo board was faulty, you need replaced motherboard or video board 9if it has), unless you can find components level repair tech near you.
Nov 27, 2008 | Acer Aspire 5610-4648 Notebook
HP PC suddenly very slow to boot up - the hp startup page (blue screen which has "esc=boot" etc) stays on for a number of minutes with the fan whirring away before a black screen appears which...
There are a number of reasons that may cause the issue but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues.
Nov 01, 2008 | Computers & Internet
HP EliteBook 8560w Mobile Workstation Logo
47 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
