Question about GE WCVH6260FWW
I have a GE WCVH6260FWW in the rinse spin cycle it counts down to 1 minute and then keeps repeating the cycle, staying on 1 minute
4 Suggested Answers
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
kf4rwe
  • 25 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Posted on Dec 03, 2008
SOURCE: ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Posted on Sep 04, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I have a front loading GE wcvh6260fww that will fill with water, but will not agitate or spin out the water...thus, no washing of clothes regardless of cycle selected. The timer counts down and the water...
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Sep 03, 2009 | GE WCVH6260FWW
Manual claims machine has ability to spin out water but there are no options on the control panel
There are different models withing this line by GE. There is one model that have a "Drain & Spin" cycle on the main cycle selection knob, but on the higher end models, you'll need to use the "Rinse & Spin" cycle.
This will add some water to the washer, but the basic cycle will give items a quick rinse and spin.
If you're trying to use just a spin cycle to wring out towels, etc. and you don't have the "Drain & Spin" cycle, (which you shouldn't based on your higher end model #), just use the "Rinse & Spin" cycle and it'll do a nice job of getting out a lot of moisture from your clothes, towels, etc.
I have this same washer in my own home and refreshed my memory by reading my manual (again) to see that this is what you need to do, to spin out stuff.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE WCVH6260FWW
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
GE WCVH6260FWW Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
