Qmax gives weak signal to all chanels - Televison & Video
When i mak the automatical programin for my tv (toshiba model no. CN27H95) it find nothing!!!! so there are others ways to mak manual programing to find chanels?
This feature is pretty reliable and the lack of channels may be due to the lack of signal to the set.
You must have either an antenna, a cable from a cable service or a satellite receiver connected for the set to find any channels.
Oct 24, 2014 | Toshiba CN27H95 27" TV
Chanel abc picture fragments
Assume you are using antenna, not cable or sat for signal.
abc signal is too low causing break up.
Reaim antenna for better reception.
Go to antennaweb.org website which should help you aim for best signal.
Feb 18, 2013 | Televison & Video
I do auto programing some chanels get program some don't
Hello
Check first your set top box's, or TVs antenna or ariel connection is tight or not. It it is Ok, if you are receiving signals from cable, ask the cable operator to check the signal strength at the cable end of your home. It is measure with a 'db' meter. If the strength of the received signal is very weak, the same channels should not mamorized, and strong signal channels only will lock in. If you are using external antena, try to reorient its postion.
Anyway your TV doesn't get sufficient signal strength.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a crown 602 channel 2 shows signal coming in, but no volume comes out. Yet when its bridge it seems to put out more power than just one chanel. Not sure where to start looking into the #2 channel...
Common problem. Power transistor in channel#2 is weak or out completely.
Bridging converts from 2 channel(stereo) to mono and you are are useing both channels in series to effectivley double your output.
Oct 04, 2010 | Crown XLS 602 2-Channel Amplifier
Full signal picks up chanels but no picture or sound appears
i would think that your emu is turned off if you have a good signal you should have supplied us with more info on box and such
May 20, 2010 | StarTech.com StarView SV211K 2-port KVM...
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
HOw to record 24 tv channels same time. is it possible? I want to record all chanells from my TV.
Anything is possible. I won't ask why, I'll just give you the information. First, you need the equipment. 24x single tuner DVRs or 12x dual tuner DVRs. Second you need to connect them all to your signal source. To do this, you are will need to install a good distribution amplifier on the signal feed to boost your source. Next, you need to connect multiple splitters of good quality to distribute to signal to each PVR. You will need to check the picture on each PVR to verify the signal integrity. If the picture is poor or weak, check you cables or splitter(s). Reconnecting these to a single TV to view the recordings... that's a whole different ball game. For this, you are going to need some A/V switches or a massive A/V matrix. A diagram would be good thing to draw up before you start this project. I hope this was helpful, best wishes.
Apr 12, 2010 | Televison & Video
You may hear .. .. . . .
you have to change your channel type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
thern check signal strength.
Thanks for using fixya.
Please rate this solution if it helps.
Jul 23, 2009 | Yahoo Messenger
RCA DTA800B1 converter box - Works great for 15 min. then quits.
I would suggest to return it because it should work as intended without dropping the signal.
It would be a good idea to add a signal booster to keep a good signal strength.
Mar 31, 2017 | Televison & Video
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
