Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Which way nut on sprayer arm turns? clockwise or counter clock
5 Suggested Answers
SOURCE: removing bolt in agitator arm
The bolt unscrews counterclockwise. Hold the agitator by the bottom vanes. If it won',t budge try tightening it first, just a little to break it free.
Posted on Dec 28, 2007
  • 198 Answers
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Posted on Jan 07, 2009
jsrock516
  • 5911 Answers
SOURCE: Need to change the lightbulb located on the freezer door. Do I turn the bulb counter clockwise or opposite?
Right-tighty, lefty loosey...that would be counter clockwise to remove, clockwise to insert. If the bulb is stuck, you may have to defrost the freezer (I know this sounds a bit extreme) to get it out easier. You may have some ice crystals keeping it lodged in the socket.
Posted on May 04, 2009
  • 2468 Answers
SOURCE: I want to remove the agitator to replace agitator
standard thread left to loosen/right to tighten,you need to use a spanner wrench or youll ruin the nut with a hammer and screw river/or chisel
Posted on Nov 18, 2010
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
Remove the sprayer hose for the forte k-10416
Use a wrench to secure the nut on the down tube. (Small vise grips worth very well) Then turn the the nut on the end of the hose counter clockwise using a wrench or basin wrench. Make sur the down tube does not turn. Good Luck 25342293-pht23pgnkin1ff0lnpbwz4vy-2-0.jpg
Dec 28, 2014 | Plumbing
How do i replace the temperature thermostat on 2002 bmw 530i show dieagram
the fan nut is LH thread. Means turn right (clockwise ) to loosen.
Jun 24, 2014 | 2003 BMW 5 Series
Porter cable pcb575bg grinding wheel. Nut on one wheel came off super easy. Nut on left wheel refuses to budge.....what's the trick ?
Nut on left wheel is reversable threaded.Nut will come off if you turn it clock-wise,,. Turning it counter-clockwise will tighten it.It has reverse threads because of the rotation of the wheel. If it wasn't it would loosen as you used it.
May 31, 2011 | Garden
Well we tried adjusting the valves and then it will start and make a werid noise and then will be about to shut off and it doesnt sound right plezz can you help me? its a 1997 gmc 5.7 1500
With the Engine in the number 1 firing position, adjust the exhaust valves for cylinders number 1, 3, 4, and 8 and the intake valves for cylinders number 1, 2, 5, and 7.
Turn the valve rocker arm nut counter clockwise until the valve lash is felt in the valve pushrod.
Turn the rocker arm nut clockwise until all of the valve lash is removed (zero valve lash).
Zero valve lash can be felt by moving the valve pushrod up and down between your thumb and forefinger until there is no more up and down movement of the valve pushrod.
When all the valve lash is removed, then turn the valve rocker arm nut clockwise 1 additional turn (360 degrees).
With the engine in the number 6 firing position, adjust the exhaust valves for cylinders number 2, 5, 6, and 7 and the intake valves for cylinders number 3, 4, 6, and 8.
Follow the same steps as above.
Apr 01, 2011 | GMC Suburban Cars & Trucks
Which direction do you turn the nut on the front left axle?
look at the beginning of the threads on the axle may have to turn it a bit. notice which way the spiral thats which way they turn, if they spiral to the left counter clockwise spiral to the right clock wise. and always start it by hand good luck!
\\\\\\\| clockwise ///////////| counter clockwise
Sep 09, 2010 | 2003 Chrysler PT Cruiser
How do you syncronize the chimes to the actual time? I inherited the clock and no instruction manual, The chimes are two hours behind the time.. Thanks
Are the hands held on by a nut? usually you can remove the nut with your fingers or a pair of pliers wrapped in cloth or duct tape to prevent scratching.
Before removing turn the minute hand (minute hand only and clockwise only; do not manually turn the hour hand and never counter-clockwise) turn the minute hand clockwise until it chimes at an hour mark.
Then remove the hands and and place them pointing to the correct time.
If you are uncomfortable with this I recommend taking it to a clock shop or jeweler that sells clocks. If it is inherited, it may need some maintainence (oiling and regulating) anyway.
Oct 17, 2009 | Seiko Mantel Clock
Is the 17MM nut to replace drive belt removed by
I think only a TNG is backwards. You will need an impact driver, turning counter clockwise.
Oct 05, 2009 | RTO Gas Motor Scooter 50cc
Upper Spray Arm Fell Off
If you are referring to the arm on the top of the dishwaser (not the one under the top basked) it snaps in. What probably happened is that it fell off and the plastic nut flipped around. The gray plasting thing on the top (that looks like a flower) will unscrew and you can turn the nut around and snap it back on and then re-attach the entire piece.
May 26, 2009 | Frigidaire 24 in. FDB435RFR Built-in...
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
12 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
