My central heating is set to max 20 degrees but we keep coming home to find house hotter than that. The thermostat is in the hallway, the boiler and froststat (latter newly replaced) are in the integral garage. The thermostat seems to shut the boiler off when 20 is reached but then it comes back on again. Potterton boiler 13 years old but has new mother board about five years ago.
    Sergeant:
  • 236 Answers
Hi Lyn,
Had the same problem with my system. turned out to be the thermostat in the hallway. Mine is an older electro-mechanical type with contacts that open and close as the temperature changes. (these type of thermostats click as you rotate the temperature dial) What had happened was the contacts had stuck closed even as the temperature rose and thus the boiler kept going. I cleaned the contacts with WD40 oil and everything is fine again. If you have the same type of thermostat this may be the problem. Be aware that if you or anyone else removes the cover of these thermostats there is live mains at the faulty contacts, be sure to switch off the circuit feeding this thermostat or remove/switch off the fuse in the main fuse box. Alternately you could replace the thermostat. If you have an electronic digital thermostat then this solution is not valid.
Good luck
Posted on Dec 24, 2013
SOURCE: Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Our Honeywell thermostat is model RTH6300B. Now that the weather is getting hot, we decided to put the centeral air on. Hot air keeps blowing out. I called Honeywell several times thinking that we had fixed the problem. It still is blowing out hot air. Also, my husband checked the wires. Has anyone else had this problem? Any ideas what it could be?
Posted on May 29, 2008
boanhtgclg
  • 34 Answers
SOURCE: temp shows 2 degrees warmer than what is was set to
sometimes the furnace does a better job than anticipated, i wouldn't worry about it, especially if the furnace shuts off.
the setpoint is the temperature you want it to be
cycle lenghts are determined by how much recovery you are requesting. for instance, in the morning when you wake up, you want the temperature to be at its setpoint. what the thermostat will do is make the furnace run a limited lengths during the recovery process.
Posted on Nov 12, 2008
  • 3249 Answers
SOURCE: Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Posted on Feb 28, 2009
  • 308 Answers
SOURCE: thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Posted on Jul 09, 2009
heatman101
  • 43501 Answers
SOURCE: Hi. We recently moved to a rented property. We
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Posted on Nov 13, 2009
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
How do I set the thermostat on my powermax 155 boiler so that the heating comes into action on a lower temperature
You should have a remote heat setting via a wall or on the front of the boiler dependant upon how it is set up. If in doubt as a Central heating engineer to install a remote one you can have next to you wherever you are in the house.
Sep 30, 2013 | Heating & Cooling
Siemens rdj10rf/set-gb problems with
There seems to be a common fault with the relay in the base unit box that's wired in to the boiler. If the black triangle is showing, the remote is demanding heat. If the two lights (green and orange) on the base unit are both lit, then it is paired and knows that heat is being demanded by the remote. However the relay sticks and doesn't actually supply current to the boiler. It can also stick in the on position so the house just keeps getting hotter. I've found that a couple of firm taps with my knuckles on the front of the base unit usually solves the problem temporarily, but if it keeps happening I think you need a new base unit (although I think you can only buy the complete kit).
Dec 18, 2012 | Heating & Cooling
I have Drayton Heating System in new home. I seem to be unable to put my central heating on without also having the water heater on. The boiler will come on if the water heating and central heating is on...
you will only be able to have the central heating on seperately if the system is fully pumped. Why would you not want the water to heat? it is more cost effective to use the residual heat to heat the water and keep the temperature up. Costs alot more to heat a cold house and a cold water tank
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
Central heating system boiling
more information required but if the boiler supplies the domestic hot water cylinder then the stat on the cylinder may be bringing on the boiler also the boiler stat may be up too high try turning it down.
Jan 05, 2009 | Heating & Cooling
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Thermostat problem ?
Oct 20, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
114 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
