Question about Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS
170-500 sigma comunication error - Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS
Canon ds126151
Hi If the canon a digital one if so the sigma 70-300 may be to old and
not compatible only if the sigma 70-300 is a super can it be rechiped
will need to be sent to sigma
Dec 30, 2013 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sigma 50mm macro2.8 for canon error 01 with my 450d and 1000d camera
This really needs to looked at by a service tech to determine the cause of the errors,before further damage is done.
Jan 21, 2013 | Sigma Af 50mm F/2.8 Ex Dg Macro Lens For...
Will a SIGMA 70-300 f4 DL MACRO LENS fit on a CANON EOS 20D?
Assuming you get the lens with a Canon mount, yes. Sigma makes lenses to fit a variety of makes, but each one has a different mount. A lens intended for a Nikon, for example, will not fit a Canon.
Dec 08, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Sigma 70-300 error 99 on canon 20d &10d
If the macro switch is held on the lens by 2 screws it is to old and will on work on your camera but if yous is a super type it may need a rechip
Nov 13, 2009 | Sigma Zoom Telephoto 70-300mm f/4-5.6 DL...
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
I am trying to use an older SIGMA 28 - 200 mm f3.5 - 5.6 DL Hyperzoom macro Aspherical AF lens with a Canon Rebel Xsi and am getting a communication error (Err 01).I have already cleaned the lens contacts...
To NOT get that error you need to use in AV mode. It's the only way that old Sigmas work with the new Canons. It's an aperture bug that old Sigma lens have and some the only way to fix it is to rechip it. The problem is that Sigma no longer rechips the lens.
May 19, 2009 | Sigma 28-200mm f/3.5-5.6 DL Aspherical...
To resolve the problem, download and install the latest service pack for Microsoft .NET Framework 1.1. Use the Windows Update feature
Apr 21, 2009 | Computers & Internet
"no lense attached" error message on my sony a200 with a sigma 70
It seems that you may have an older sigma lens which does not have the appropriate electrical connections. Sigma can modify this for you if you contact them, and I believe the cost is reasonable. Although some lenses look very similar, there are electrical differences between earlier and newer lenses, even though they may fit on to your camera mechanically,
Mar 15, 2009 | Sony Alpha DSLR-A200K Digital Camera
Err 01 Communication between Camera & Lens is Faulty
cleaning the contacts did nothing for me. what ended up fixing it was turning the camera to AV mode and setting to the highest f value. (f22) and then taking a picture. after that i was able to change it to what ever and resume as normal. hoping i dont see that error again.
Dec 02, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
Open Questions:
See all Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens Questions
Sigma AF 70-300mm f/4.0-5.6 DL Macro Super Lens for Canon-EOS Logo
29 people viewed this question
Top Sigma Cameras Experts
Doberman
Devabhakthuni...
Devabhakthuni...
Are you a Sigma Camera Expert? Answer questions, earn points and help others
