Question about Desa International Heating & Cooling
I have a Desa EFP33PR. The pilot will light in both manual and auto however the main gas will not light. The flame is perfectly blue and the thermocouple is directly in the flame. I am assuming either the thermocouple or the wire to the thermocouple is bad. I cannot seem to find a direct replacement online. I see very similar replacement parts online but none exact. Any suggestions? Also I have made sure all the vent holes are clean and the thermocouple is clean as well.
    Top Expert:
  • Desa Interna... Master
  • 34,711 Answers
Maybe Desa can supply a replacement thermocouple.
Posted on Nov 24, 2013
  • Michael Milhorn
    Michael Milhorn Nov 25, 2013
    I wish it were that easy. Desa went bankrupt in 2008. I'm going to try calling / going by a local fireplace shop and see if they can help me. I can easily replace the part if I can find it.
koolbreezes
  • 540 Answers
SOURCE: i have an older model williams furnace co -
Check out the Grainger catalog, they will have everything that is obsolite but you might have to pay more.
Posted on Dec 18, 2009
  • 439 Answers
SOURCE: Radiant Flame Heater by DESA International pilot
You need to replace the pilot light. This is an easy replacement, it goes from your gas control valve to its place in the heater. You can try "taping" the dust out or pulling it out and blowing it clear. This will fix your pilot light problem.
Posted on Sep 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have blue rhino patio heater, the pilot will
If the pilot gets the least bit of dust in the safety will mimmick a low oxygen situation and cause the heater to shut down. The fix is easy. You must blow out the pilot safety device. More HERE
Bonus video demo of ODS safety system
Posted on Dec 31, 2009
  • 2514 Answers
SOURCE: The pilot light on my Deas heater keeps going out
20 to 30 mille volts or just change it
Posted on Feb 17, 2010
  • 4736 Answers
SOURCE: It is a Williams circa
That hole should only be a problem, if a strong draft comes thru and blows the pilot out. But that hole may also be for match lighting the pilot in an emergency. The older models like yours, had that feature. Check it closely, before you decide to block off the hole.
Hope this helped you.
Posted on Jun 19, 2011
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Cannot get gas to flow to pilot flame with main valve parallel to gas pipe. Is there something I must push to make gas flow to the pilot flame pipe?
you said, in effect: Cannot get gas to light the pilot flame even though manual supply valve is open. Is there something I must push to light [ignite] the pilot? Permalink
The gas supply valve is open, and the pilot gas cutoff valve is open but [it seems like] gas will not flow to the pilot flame because it will not light when I supply a match or lighter flame. I remember there is a button or something I need to press...but where it it? I cannot find it.
Nov 03, 2014 | Heating & Cooling
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Sep 13, 2011 | Desa International Unvented Gas Space...
Pilot doesn't stay light
A common problem with gas logs is a dirty pilot orifice that causes a lazy yellow pilot flame. So when the burners cycles off, the additional heat from the main burners no longer helps heat the thermocouple, so it cools off enough for the 100% safety cut-off to shut it all down. Take a look and see what that pilot flame looks like. It should be a stiff blue flame impinging on the thermocouple making it red hot. Here's a quick solution for this issue. Shut it all down. Let it all cool off. Remove the logs as necessary to access the pilot assembly and using a can of compressed air with an attached straw (like you use for cleaning computer keyboards), blow out the pilot orifice. It could also be a spider web, so check it out with a flashlight too. I hope this resolves your problem. Let us know if it worked or if you need more assistance.
May 17, 2010 | Desa International RFN30T Open Flame...
My propane fireplace pilot light wont stay lighted help
Most gas valves have a flame sensor, which is a metal bulb at the end of a wire. The pilot light heats this bulb, and the valve stays open because there's a flame. If the flame has been out, you'll need to hold down the pilot light button for as much as two minutes after lighting the flame to allow the flame to heat the flame sensor up enough to keep supplying gas when you release the button.
Mar 17, 2010 | Desa International CCL3018N 18KBTU VNTFRE...
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT WILL NOT STAY LIT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
Oct 13, 2009 | Desa International Heating & Cooling
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
Radiant Flame Heater by DESA International pilot light will not stay lit. The manual is not available. Could this be a thermocouple? If so, how do I change it. The flame in the "logs" will light...
Sep 29, 2009 | Heating & Cooling
Desa TD 104 Patio Gas heater
Sounds like you may not be getting enough gas up to the main burner. Bugs, such as spiders, love to make homes out of the main supply lines. Does your pilot light burn blue, and strong? If not, it may need to be cleared of the obstruction. Also, when opening the the gas tank valve, are you opening it slowly?
Feb 08, 2009 | Desa International TD104 Patio Heater
Heating & Cooling Logo
87 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
