Question about Proform 650 Crosstrainer Treadmill
Treadmill turns on but turns itself off
I turn on my treadmill, it starts at a high speed, then turns itself off. The display also rests.
    New Friend:
  • 326 Answers
This may be a problem with the LCB.
Posted on Dec 04, 2013
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Treadmill automatically speeds up upon start up
If you have a unit where the speed can be adjusted with 1 mph increments 0 to 10 and with speed up or down .1 mph increments . it sound like the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill turns off
Check you Drive Motor : Get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery If good, the motor should operate at about 1 MPH. Or if you have a extra car battery- these are 12 VDC high amp batteries so the motor will turn slowly but you can walk on the belt. If you have the same problem it could be worn motor brushes.
Posted on May 15, 2010
ercupa190
  • 12223 Answers
SOURCE: Display Doesnt turn on
1) change the batteries by news one
2) clean the contacts batteries very well
3) tight the ribbon cables from keypads from display board.
4) tight the wires connector from display board vs lower board
5) Adjust the reed switch see the diagram, clean it and tight the wire connector well.
6) After you fix it RUN the software calibration for diagnose , troubleshooting and fix it.
God bless you
Posted on Jul 13, 2012
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Jun 13, 2010 | Spirit Fitness Z500 Treadmill
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Treadmill turns off
May 14, 2010 | Proform CrossTrainer Treadmill
Mar 01, 2010 | Proform Exercise & Fitness
Proform CS17e speeds up by itself after 10 minutes.
You probably need a new speed censor. If you bought it new that part should be covered under warranty. www.AtlantaFitnessRepair.com
Aug 24, 2009 | Exercise & Fitness
Proform 650 Crosstrainer Treadmill Logo
114 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
