Question about Refrigerators
Refrigerator temperture set
What is the correct setting for a kelvinator fridge freezer
    Champion:
    Habit-Forming:
  • 279 Answers
MId way on the temp setting is the best place to start.
Posted on Nov 29, 2013
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
  • 1462 Answers
SOURCE: Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
SOURCE: zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Posted on Mar 28, 2009
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
  • 363 Answers
SOURCE: fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Posted on Jul 26, 2009
mine has 5 setting, i dont know what model you have but i set mine on 3 and it keeps everything frozen, you may have to experiment as to what setting you like to have it
Nov 24, 2013 | Kelvinator Freezers
I have a Kelvinator Fridge P120 Product Code: 10325 and we have no manual for the defrost or temperature dial settings can you help me with a pdf Manual?
Hi Aaron, Apparently this is a Fisher & Paykel fridge made by Kelvinator.
F&P has a support page for manuals, etc., here. I found a fridge / freezer user manual, here. F&P maintains that this manual is applicable to all of their fridge / freezers, so don't be put off by all the model numbers covered (the P120 model is specifically listed however).
If this is not the correct product, please let me know & I'll see if I can find the one for your appliance. I hope this helps and good luck!
Mar 05, 2012 | Refrigerators
Kelvinator fridge freezer, fridge too cold frosting at back
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Mar 28, 2011 | Kelvinator KBM5100MB
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Cannot keep fridge at proper temperture,keep trying different settings
The fridge section runs off of the freezer..
Set the freezer close to recommended factory setting.. If you want things a little colder - go a little higher - etc..
Set the fridge setting close to recommended factory setting..
The recommended settings are usually pretty good and help the fridge run at peek performance..
Any change in settings will take at least 12 hours or more to take effect..
Sep 29, 2009 | Hotpoint Refrigerators
Freezer and Fridge at wrong temperture
How old is this fridge? Your themostat may be shot. Put an accurate thermometer in the freezer and cooler to ge the real reading. If they are the same as on the door then the themostat is probably the problem. If not, it could be that all you need is a new display.
Dec 17, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
