Ba 1st year result
I know my result
Where is ford ba heater diagram?
ford Fairmont?
what year,
what country.
ba? what is a ba. (big axx) or>?
Down under are you?
this
http://en.wikipedia.org/wiki/Ford_Falcon_%28BA%29
a Ford BA Falcon
May 03, 2014 | Ford Fairmont Cars & Trucks
Plz tell me date of 1st year result
First year result of what? Some school thing? Medical? What?
Oct 03, 2013 | Office Equipment & Supplies
I've had my TI BA !!+ a long time and do mortgage payment calculations on it. Today, however, it gives wildly wrong answers. I checked my calculations on an amortization program I have on my computer and...
Check the BGN/END setting (2nd [BGN]) and the number of payments per year (2nd [P/Y]). If those are set correctly, could you post an example, also giving the result you're getting and the result you expect?
Nov 12, 2010 | Texas Instruments BA-II Plus Calculator
I am using Texas BAII Plus. The problem is when I try to calculate the NPV, N, PV,PMT, FY. it does not provide the right figure. It was ok until this morning. I think I might press something wrong....
Check the BEGIN/END setting (2nd [BGN]) and the number of payments per year (2nd [P/Y]). If these are set correctly, could you post the problem you're trying to solve, giving both your results and the expected results?
Oct 27, 2010 | Texas Instruments BA-II Plus Calculator
What buttons do I push in what order to figure compound interset. if I start with$15,000.00 at 6% interset for 25 years. I am on a texas instrument ba 2 plus
If the interest is compounded monthly:
2nd [CLR TVM] (clear any existing results)
1 5 0 0 0 _/- PV (present value, negative because you're paying it out)
6 I/Y (annual interest rate)
25 2nd [*P/Y] N (25 years)
CPT FV (compute future value, see 66,974.55)
If the interest is compounded annually:
2nd [P/Y] 1 ENTER 2nd [QUIT] (one compounding period per year)
25 N (25 years)
CPT FV (compute future value, see 64,378.96)
Oct 26, 2010 | Texas Instruments BA-II Plus Calculator
My TI BA II Plus is returning incorrect answers for TVM problems... Is this common and can it be fixed?
It's more common that one of the settings is not correct. Check the BEGIN/END setting, the number of payments per year, and the number of compounding periods per year.
If you still have problems, please give an example of a TVM problem, with your results and the correct result. Simply saying "incorrect results" doesn't let anyone help you.
Oct 05, 2010 | Texas Instruments BA-II Plus Calculator
Hi, I am using my BA I Plus to do the following cal.: N = 6 I=7 PMT = -42000 FV = -700000 this is a problem about bond. Couple days ago, when I entered the above input, I get the same as the...
Check the number of payments per year. With one payment per year the present value is 666,634, while with twelve payments per year the present value is 922,926.
You probably changed it while working out another problem.
Oct 03, 2010 | Texas Instruments BA II PLUS Financial...
I am getting answers a little off from the real answer and dont know if there's a setting i need to change
There are several possibilities. Are the payments made at the beginning or the end of each period? Is the interest compounded annually, semi-annually, monthly, or some other period? Without more details, no one can diagnose your problem. Could you post the problem, giving both your results and the expected results?
Sep 03, 2010 | Texas Instruments BA-II Plus Calculator
49 people viewed this question
jasbo
jasbo
