Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
Posted on May 07, 2009
Jenn-Air dual fuel range JDR8895AAB caught fire last week.
It hadn't been used in several days as we had been on vacation so no moisture was under the knobs as may have been the problem in previous posts. Clicking came from the ignitor, and then fire from the center burner and then one by one all of the burner knobs burst into flame! Jenn-Air sent a repairman to the house who said the wire for the switch was shorted. I do not want this range in my house any longer even though the repairman says it can be fixed. I do not trust that it will not happen again. Any ideas as to what to do to get satisfaction from Jenn-Air?
  • shannie42 Dec 09, 2009
    Jenn Air gave us a prorated credit toward a new range which we purchased at Sears. Took a few phone calls and some back and forth, but they were not difficult about it and had someone come and haul the Jenn-Air away.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 09, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
732
Points
The exact same thing just happened to our same model last night. Did Jenn-Air fix it?
JDR8895AA Jenn-Air Double Oven free standing. Power was shut off during goutside generator maintenance; that was a week ago. No lights / noise on contol panel and 3 sec push on clock button doesn'
Not to be a smart aleck but have you checked the breaker box to see if the breakers are on also the standby breakers? Not sure how your'e wired though.
or reset to factory.... 1. Press and hold upper oven Keep Warm and Upper Cancel pads for 3 second. Should get a single beep. Then clock will show 12:00.
per repair manual Jenn-Air Repair-Manual-JDR8895AAB-JDR8895AAS-JDR8895AAW
Several Gas Burner Igniters spark every 5 seconds even when all burners are turned off. Jenn-Air Dual Fuel Range JDR8895AAS Help, and Thanks! -- Larry
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
My Jenn Air Dual fuel slide in Range (2003) Mdl JDS9860AAB Resets itself as if it had lost AC power. This happens about once a week. or if I am cooking an important meal (like Thankgiving) It resets itself...
Main micro-processor, clock control defective, replace clock control or it power supply board. It's recommended to replace power supply & control if this unit has the two on seperate boards.
3helpful
No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Jenn-Air JDR8895 dual fuel--ignitors won't work after flood
hi your ignitors wont last long, they are similar to a fuse, you should be able to change the ignitor and if it still does not ignite look to see the space of the ignitor and try shorten it.
Jenn Air Dual Fuel Fire problems
We decided to go with a different stove. Thanks anyway!
How do I get to the grease containers?
The grease container is at the bottom of the range. If you remove the front panel there is a little plastic cup that holds the grease. Hope this helps!!
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
