Question about 95-02 Pontiac Sunfire 2.2L T3/T4 Turbo Kit with Turbonetics Turbo
Head gasket replacement
I need head gasket torque specs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You can get it at the public libray in the auto section ok
Posted on Nov 25, 2013
Thermo king 2.2deisal head bolt torque spec
These days the torque specs tend to be supplied with the replacement head gasket.
If stretch bolts are used the bolts might need replacing and only a small initial torque figure will be needed and thereafter the bolts should be tightened by angle. I can't supply the figures but I can provide the procedure if you have any doubts.
Sep 22, 2017 | Cars & Trucks
What are the torque specs for head bolts on a 2003 Ford Windstar Van?
When doing such major work, there are other parts that need correct torque and sequence as well. Buy a cheap shop manual from an auto parts store for this info and so much more.
Oct 03, 2016 | 2003 Ford Windstar
Can anyone.tell me the Torqe specs for a 2004 or cruiser
Head and Cam Bolt Torque specs? - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 5, 2012 - 2 posts - ‎2 authors
I am putting everything back on after replacing the head gasket. I was wondering what the Torque Specs and Sequences are for both the Head ... Torque Specs
Jul 28, 2012
Valve cover torque specs
Jul 4, 2011
Timing Repair Project - Bolt Torque Specs
Jun 16, 2011
torque specs?
Mar 20, 2006
More results from www.ptcruiserlinks.com
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts ...
? 5:07
https://www.youtube.com/watch?v=2wB2o27eWgo
Aug 20, 2015 - Uploaded by World Mechanics
Dodge Stratus / Chrysler Pt Cruiser / Sebring Camshafts Install and Torque Specs 2.4 Engine. ... 2004 Chrysler PT CruiserCamshaft Install
Dodge Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head ...
? 6:08
https://www.youtube.com/watch?v=7rY7tDbye-8
Aug 16, 2015 - Uploaded by World Mechanics
... Stratus / Chrysler Sebring / Pt Cruiser 2.4 Head gasket Install and torque specs We took this video to ... 2004 Chrysler PtCruiser head gasket
Jan 18, 2016 | Cars & Trucks
Need torque specs to replace head gasket on a 1989 plymouth voyager
Normaly supplied with the head gasket with the sequence in which to tighten them.
Jun 24, 2012 | Plymouth Voyager Cars & Trucks
HOW TO FIX A BLOWN HEAD GASKIT?
Buy a gasket kit for the upper end. Remove the valve cover intake and exhaust manifolds. Remove the head bolts. Remove head and clean up block from old gasket material. Take the head to a machinist and make sure that it is not warped. If it is warped either replace the head with a new one or have it machined true. Install new gasket and get torque specs with new head bolts and follow torque sequence using the correct torque specs. Clean exhaust, intake and valve cover of old gaskets. install new gaskets and torque according to specifications.
Nov 27, 2010 | 1993 Jeep Cherokee Country
NEED FORD 2.2l head gaskets torque chart
Tighten the head bolts 29 to 32 ft lbs , then tighten again to 59 to 64 ft lbs
Apr 17, 2010 | 1989 Ford Probe
Torque spec
Head bolt torque is 32 ft.-lb. (43 nm)
Head cover bolt torque is 7 ft.-lb. (10 nm)
Mar 25, 2010 | 2000 Yamaha Royal Star Venture
Need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
Sep 18, 2009 | 2000 Ford Focus
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
95-02 Pontiac Sunfire 2.2L T3/T4 Turbo Kit with Turbonetics Turbo Logo
80 people viewed this question
Top FastWayRacer Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a FastWayRacer Vehicle Part and Accessory Expert? Answer questions, earn points and help others
