Question about Car Audio & Video
Kenwood dnx6990hd won't turn on
Unit will no longer turn at all
Head unit wll not stay on
You either have a loose connection on your head unit or a fault with the unit take it to. Car audio store get them to connect it up on the bench if it stays on faults in your wiring.
Jun 21, 2014 | Kenwood DNX-6990HD Double-Din indash...
Screen goes crazy
It could be a wire that become exposed in the back of the radio. If it works good when your engine off. It's doing it when you have the engine is runing because more things are running wich could cause a short out.
Feb 14, 2014 | Kenwood DNX-6990HD Double-Din indash...
Kenwood car stereo face got wet and now won't work, how do i fix it?
If the unit is already fried you may try to soak it in the highest alchol % of rubbing Alcohol for a day then allow the unit to dry Which should happen within a day or so because of the evaporation rate of the alcohol. This should remove the internally locked water and allow for the unit to resume Function without internally shorting.
Jun 06, 2013 | Kenwood KDC-MP242
RCA jacks on kenwood head unit do not function
Just run your amp on the front RCA and tune it on your amp they can blow which sounds like whats happend hope this helps
Mar 18, 2013 | Kenwood Car Audio & Video
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Feb 03, 2013 | Kenwood Car Audio & Video
I was having alternator problems a week ago,so i turned off my stereo so my battery would last longer,I put in a new alternator on the expedition and now I've been trying to turn on my stereo and it...
Thanks for choosing FixYa. More then likely, you need to enter the unlock code on your radio. It locks up when there is a power loss. As far as the code, it may be in your owner manual or you may need to contact Ford to get it.
Jan 25, 2012 | Kenwood Car Audio & Video
Kenwood VR-2090 was overloaded and no longer works. Can i personally repair the unit?
I don't think so because the audio amplifier IC of the device are damaged you need to send it to a repair center.Good luck
Jul 25, 2008 | Kenwood Audio Players & Recorders
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
