Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Receives fine transmission is very poor - Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
Transmit issues can be related to a bad or poorly charged battery. It takes more energy to transmit than to receive. Try swapping batteries with a known good radio to see if it solves the problem. Clean your battery contacts with a pencil eraser and if needed replace the battery pack.
Best regards.
Posted on Nov 27, 2013
2004 pontiac sunfire wont shift out of park
Problem with shift interlock system .
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid
The body control module (BCM)
The powertrain control module (PCM)
With the ignition in the ON position, battery positive voltage is supplied to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid receives a ground from the BCM. When the automatic transmission shift lock control solenoid is energized, the shift lever mechanically locked in the PARK position. When the driver presses the brake pedal the PCM sends a class 2 serial data message to the BCM. The BCM turns OFF the ground control circuit and this de-energizes the automatic transmission shift lock control solenoid. When the automatic transmission shift lock control solenoid is de-energized, the shift lever may be moved out of the PARK position. The BCM determines transaxle shift lever position through a class 2 serial data message from the PCM. The PCM receives inputs from the park/neutral position switch and determines shift lever position. When the BCM receives this information and determines that the shift lever is out of the PARK position, the automatic transmission shift lock control solenoid ground is opened.
Did you perform the A Diagnostic System Check - Automatic Transmission Shift Lock Control?
Go to Step 2
Go to Diagnostic System Check - Automatic Transmission Shift Lock Control
  1. Turn ON the ignition, with the engine OFF.
  2. Press and hold the brake pedal.
  3. Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the automatic transmission shift lock control solenoid.
  3. Turn ON the ignition, with the engine OFF.
  4. Attempt to move the shift lever out of the PARK position.
YES - Go to Step 4
NO - Go to Step 5
Test the A/T shift lock control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 9
NO - Go to Step 6
5
Inspect for poor connections at the harness connector of the automatic transmission shift lock control solenoid. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 9
Go to Step 7
6
Inspect for poor connections at the harness connector of the body control module (BCM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 9
Go to Step 8
7
Replace the automatic transmission shift lock control solenoid. Refer to Transmission Control Replacement in Automatic Transaxle-4T40-E/4T45-E.
Did you complete the replacement?
Go to Step 9
8
Replace the body control module (BCM). Refer to Body Control Module Replacement in Body Control System.
Go to Step 9
9
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jun 29, 2016 | Pontiac Cars & Trucks
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Err code 322 every time ces up on my HP 6600 print scan web copy n faxachine .
Video might not help but 322 is an error with the receiving fax machine due to poor telephone line conditions. Solution is to set the receiving machine to receive at a slower transmission speed if it still fais resend the documents in smaller sizes. Hope this helps
Apr 16, 2013 | Office Equipment & Supplies
A buzz accompanies transmission
Hi Richard
This is nearly ALWAYS caused by (A) A poor connection with cabling that is too small or long for the amp draw when transmitting, or (B) Low battery voltage or alternator output.
I'd check the power and ground cables first, and use a cable gauge at LEAST one size bigger.
Oct 24, 2011 | Icom IC-V8000
Canon fax l100 .........problem error100.........help me and thanks
This error means the receiver cannot receive the file properly due to poor line signal or conditions. If there's a feature that you can adjust the transmission level, try to boost it. You also need to set the speed 4800 bits per second. There are many solutions, but they can only be implemented by the technicians. This error also signifies that the receiver's machine isn't receiving the file/data because of low transmission level. If you can set the echo counter-measures, that'd be very helpful. Also try to dial the receiver's number slowly, sometimes this helps. I am sorry that I can't provide you more than these information since you'll not understand even if i do. If you insists, i'll do it for you. Good luck. Thanks for using FixYa.
Jun 06, 2010 | Office Equipment & Supplies
Error code #0005 what does it mean? and possible causes?
Found the cause of the error, basically the other end is having trouble most likely poor line conditions.
##005 [ TX ] Failed G12 reception during G2 transmission.
A. Cause: Other party cannot properly receive the G12 signals due to poor line conditions.
Solution: Have the other party boost their transmission level so they can properly receive G12 signal.
B. Cause: Other party confused by echo and does not send G12.
Solution: Have the other party lower their transmission level so they will not receive echo signals.
Apr 15, 2010 | Canon LaserCLASS Fax 710 Printer
Magic Jack quit transmitting, but receives on Brother 775 fax
wheneva i start ma magic jack it say connect to internet an put password its says correct but thn again its comes again connect to internert.... an password an email id... but pls help me in tis..??
Jan 07, 2010 | Lands Phones
Transmitting
its the coax. i had this same issue. i thought a bought a great strand but, it was very poor in design and it developed many breaks over time, reducing its transmitting ability. I would also check the mic wire and head connections as well. this is a problem spot at times.
Feb 25, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Scratchy Transmission
The first thing which comes to mind is a bad battery pack. You might try switching the batteries between the two units and see if the problem moves to the other unit.
Secondly, if you only have two radios, it could be the opposite radio has poor receive. You could have a damaged or defective speaker in the receiving unit.
Third, check the speaker grill and mic holes on both units to see they are clear of debris.
If all these items check out, you may need to eventually replace the defective radio. However, to determine which one is defective by trying them with a known good radio.
Jan 13, 2009 | Motorola Talkabout T6210 (14 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
65 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
