Question about AM Auto Parts 1995 Buick Century 12 Tooth Power Window Motor OES StyleSet of 4
Acceloration when I stop for a light or stop sign and proceed to my desired speed the car sometimes doesn't accelerate for the amount of pressure applied to the gas.
    Genius:
  • 1,198 Answers
At this age, it's time for a good checkup. Ask around for a mechanic with a good reputation. He will probably want to replace vacuum lines, filters, and do a full tuneup. Also the transmission needs to be checked, hopefully he can do that too.
A good tuneup can cost a couple of hundred dollars, it takes time to check all that stuff. Some belts are expensive, and installing them is difficult. You don't want old belts to fail, that's even worse.
Posted on Nov 25, 2013
Hesitates on acceloration
Clean the throttle body and the idle air control motor. Pull the Idle motor and clean it with a brush and pick. Use brake clean. Get as much black/carbon off of it as you can.
Sep 04, 2014 | Cars & Trucks
When accelorating rpms and engine get stuck
Put a vacuum gage at e port on intake,low vacuum while accelerating could indicate a block catalitic converter or remove o2 sensor at manifold to remove restrition ifroad test ok change cataltic conv. sometime you could exhaust pipe very blue ish
Apr 22, 2014 | Chevrolet TrailBlazer Cars & Trucks
96 prizm stalling at stops. sputtering when accelerating and especialy when not accelerating. If I give it alot of gas it doesn't sputter or jump.
Sounds like your Idle Air Control valve is bad. The IAC valve controls the engine idle speed. The valve is located on the side of the throttle body. This valve allows the necessary amount of air, as determined by the (PCM) and controlled by a duty cycle signal, to bypass the throttle plate in order to maintain the proper idle speed. Good luck!
Jun 12, 2011 | Geo Prizm Cars & Trucks
My 1998 Jeep Cherokee will start but will not shift out of first gear. Any solutions?
Is the check engine light on? Does the speedo work? Probaly is either a bad output speed sensor on the trans tail hosing or a bad govenor pressure solenoid and /or pressure sensor on the valve body. Need to have it scanned. Output rpms should be zero at a stop and increase with road speed . Govenor pressure should be within 3 psi of desired govenor pressure . Desired govenor pressure should match road road speed.I would recomend replace the sensor and solenoid as a pair.Please vote and good luck!
Jan 21, 2011 | 1998 Jeep Grand Cherokee
I want to know how to use my cruise control in my 1994 Toyota pickup. It has all the buttons and the capability but the words are scratched off and i don't have a manual.
Generally... There is ON/OFF - SET - ACCELERATE/RESUME, COAST/DECELERATE. Cruise is available at speeds above 35mph or so. Sometimes there is no main on/off. Cruise on a turn signal stem has a button that pushes in on the end, push when at desired speed. resume/accelerate slides to right, is spring loaded and return left when released. the same lever when slid left is coast/decelerate. Momentarily sliding accelerate and releasing increases crusing speed by a couple mph. If brakes are used cruise disengages, sliding resume returns you to cruise speed after braking. Coast/decelerate disengages cruise, when at desired lower speed hit set. On some, hitting set not needed, when coast is released speed is maintained. Variations may be up/ down instead or may be steering wheel face mounted. Please rate answer. Duct tape is like the force, it has a dark side.. a light side.. and holds the universe together!
Jun 12, 2010 | Cars & Trucks
1997 Suburban 4x4 5.7L Transmission whines until it shifts
You rear planetary set is worn from a restricted cooler.
May 06, 2009 | 1997 Chevrolet Suburban
My 86 cadillac shakes, when i stopat a stop sign
im not sayin shiit ******** you want to charge for your little ******** not sure remedy ********........i fixed it...
Feb 18, 2009 | 1983 Cadillac DeVille
Isuzu trooper engine stops while driving
If its the 3.0 diesel it could be the rail oil pressure sensor starting to pack up .
Jan 21, 2009 | 1999 Isuzu Trooper
AM Auto Parts 1995 Buick Century 12 Tooth Power Window Motor OES StyleSet of 4 Logo
73 people viewed this question
Top AM Auto Parts Home Experts
ray gallant
Denis Houle
Denis Houle
Are you an AM Auto Parts Home Expert? Answer questions, earn points and help others
