Question about Toshiba 46SL417U LCD TV
Toshiba 46sl417u won't turn on green flashing
TV will only have green led flashing three times then a pause and repeats
5 Suggested Answers
  • 3 Answers
SOURCE: Toshiba 42LX196. No picture, no sound. Power
it is the power supply if you know how to soder you can just change the switch for 20 bucks
Posted on Jan 27, 2011
tbreeze47
  • 3083 Answers
SOURCE: Our Toshiba 42HL196 TV refuses
If the tv doesn't reset after being unplugged awhile, there's an internal problem, and the unit will have to be serviced. Make sure the cable input isn't loose, and that the cable cord is good. Aside from that, there's not much you can do. Some cities have mobile TV repairmen that will service the unit in your home, and it's much more convenient. Look in your Yellow Pages under TV Repair.
Good luck, and hope this helps.
Posted on Mar 01, 2011
  • 76 Answers
SOURCE: REGZA 47HL167 TV is difficult to turn on. when
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
http://www.youtube.com/watch?v=oDGjWOabJ2E&feature=related
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1&feature=fvwp
Posted on Oct 07, 2011
vinceisaac
  • 2432 Answers
SOURCE: The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Posted on Oct 03, 2012
What may cause screen to turn green and then black out.? power LED is blinking three times then pause and repeat. unplugging tv did not resolve problem. single click can be heard from center of tv wh
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 05, 2014 | Toshiba Regza 55SV670U LCD TV
You turn on the TV, the green light flashes 3 times, then flashes three times again. It turns on great picture, you can open the menu, change sound up or down or mute it. Then about 15 seconds later you...
have you had the freeview board off and used tv with it not on. sometimes the built in free view board can fail and use the processor speed up. so no menu etc also will affect the inputs..
Oct 01, 2013 | Toshiba 46SL417U LCD TV
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Led lights flashing
replace the lamp. the lamps basicly have 3000 hours before they go, and also depends on the number of times the unit is turned on and off which greatly lessens the life of the lamp.
Feb 26, 2008 | Toshiba 46HM95 46" HDTV
TV won't turn on
problem is fan stoppage this is probable caused by excessive
dust in fan take off back and locate visually the cooling fans in unit
use canned air to remove dust until fan moves freely. if all fans
are clean maybe one fan is not giving rotation detect signal
look at voltage on white or yellow wire from fan s/b 5v then 0v
when fan rotates if one stays at 5v replace it
Jan 07, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Toshiba 46SL417U LCD TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
