Question about SuperMicro MB X6DAL-B2 E7525 RT (MBDX6DALB2) Motherboard
Supermicro x6dal-b2 CMOS error press f1 to enter setup or f2 to use defaults and continue
Clent tried to flash the bios now it won't save any settings and keeps coming back to CMOS error
    Brigadier General:
  • SuperMicro Master
  • 3,400 Answers
TRY WITH CLEAR CMOS IT SHOULD HELP.
Posted on Nov 24, 2013
Testimonial: "Been dere done dat didn't work"
3 Suggested Answers
  • 11800 Answers
SOURCE: I have just builed the PC with Supermicro P4SCA
Maximum processor supported: Intel Pentium® 4 processors or Intel Celeron processors up to 3.06 GHz (with Hyper Threading) at a system bus speed of 800/533/400 MHz.
Yours is too fast for the motherboard, replace it with an older weaker one.
Posted on Feb 04, 2010
  • 669 Answers
SOURCE: how do i make my supermicro X6DAL-B2 motherboard more compatable with windows 7?
Sounds like you need to go to the manufactures website and download the latest drivers. I would do this for the motherboard and any equipment plugged into it (soundcard, graphics adapter, monitor, printer). Update everything. Then you might also trying cleaning up things. For example: how full is the recycle bin? When was the last time you defragged the harddrive? How much stuff do you have running in the background? Is windows up to date? When was the last virus/malware scan done and is the software upto date? All these things should be looked at.
Hope this helps
Posted on Mar 12, 2012
When I startup my pc I have to press F1 before it starts . I am running windows xp home
This has nothing to do with windows, but is a cmos or bios issue. There should be an error something like, Time incorrect press F1 to continue or F2 to enter setup. Check the error and then press the correct key to enter setup. If the issue is the time, fix the time and date in set up. Most other issues will clear when you exit and save set up.
If you would like more information, please provide the exact wording of the error that you are pressing F1 to continue from.
Dec 14, 2011 | Microsoft Windows XP Home Edition
My computer displays press F1 to continue F2 to enter setup every time start
The CMOS or the Coin cell battery is dead you need to replace it. Once you replace it go to BIOS setting by pressing F2 at the dell logo and select load setup defaults after that save and exit.
Sep 03, 2011 | Dell Computers & Internet
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT AFTER THE SHUTDOWN WHEN I RESTART IT THERE IS AN ERROR ..LIKE THIS CMOS SETTINGS WRONG ...CMOS SYSTEM TIME/DATE NO T SET...PRESS F1 TO RUN SETUP...PRESS...
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Nov 06, 2009 | ASUS P5PE-VM Motherboard
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
SuperMicro MB X6DAL-B2 E7525 RT (MBDX6DALB2) Motherboard Logo
87 people viewed this question
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
