Question about Frigidaire Affinity ATF7000E Front Load Washer
My frigidaire Affinity washer won't let me select the temperature of the water or the speed of the cycle on the normal, bulky or heavy settings only? It is NOT THAT OLD a little over a year!
5 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
Posted on Jan 31, 2009
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
Posted on May 21, 2010
richroth
  • 9472 Answers
SOURCE: Frigidaire gallery washer won't change cycles
Look at my other post to you.
Posted on Oct 31, 2012
richroth
  • 9472 Answers
SOURCE: my Frigidaire affinity front load washer will not fill with water on bulky,heavy and normal wash modes but works fine on delicate setting
What is the model number of your unit?
Posted on Nov 01, 2012
Fafs4272lw0 affinity washer
Hello Brenda - I am more than happy to assist you! First, let's try resetting the washer machine. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit back on. Once the unit is operable, please select the Normal cycle and press one of the two selections. If the issue persists, then in the case the appliance may be experiencing a communication error with the control board, a potential wiring failure or a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Jul 18, 2013 | Frigidaire Washing Machines
How to I reset my Affinity to factory settings? I know you hold down to buttions for a few seconds but I forgot which buttons they were.
Hello, Thank You for using FixYa. I will be helping you today.
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | Frigidaire ATF6000ES Front Load Washer
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
