Question about Canon CanoScan 4200F Flatbed Scanner
Could not find TWAIN
PC cannot find scanner
  • 4 Answers
Hi there
If you want to get a twain scanner,you can just refer to this program,which i have used for a long time.It offers a free trial for new users.You can have a try.Hope to help you.
TWAIN TWAIN Scanning in Overview
Posted on Jan 10, 2014
Can't connect fujitsu 5120c scanner to windows 7 machine
To connect your Fujitsu fi-5120c scanner to Windows 7 PC, you need to install the TWAIN driver for Windows 7. Please download the driver update from the link provided below:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v9211013.html
Hope the above information is helpful.
Please feel free to to contact us for further assistance.
Thanks & regards,
ScanCare
Sep 04, 2011 | Fujitsu fi-5120C
Reinstalled canoscan LIDE 200 on pc after we did a format its a Twain everything works except the toolbox when i try to scan a pdf says something about changing it to Twain we have uninstalled and...
Twain is the scanner interface program on the computer. Something is missing from the install or the XP system software. Double check to make sure you're installing an XP-compatible version of the scanner software. The program for newer versions of Windows likely assumes the presence of some software components that may not be there in XP unless the install program puts them in. Without those missing pieces, Twain won't load properly.
Aug 28, 2017 | Canon Computers & Internet
After reformatting my computer I have treid to reinstall the scanner and the software tells me the twain driver is missing. I went to canon website and downloaded the twain driver for the canoscan N670U....
Please check whether your scanner gets detected while connectiNg to your PC. If not please check your cable.Did you down loaded the correct driver that is meant for your OS? Please check. One more thing is the PCB at the bottom of your scanner is getting heated up? Then it canbe a problem regarding your PCB. Just replace it
Apr 18, 2011 | Canon CanoScan N670U Flatbed Scanner
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Jan 14, 2009 | Office Equipment & Supplies
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Twain drivers
The problem was with the scanner,it was not twain compliant
So the 2 ways left with me was :
1.Download twain drivers for my scanner and install it.
2.Use wia32.dll
I chose second option as i didnt found any twain driver for my scanner.
Hope this can help any one.
Aug 30, 2008 | Office Equipment & Supplies
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Apr 12, 2008 | Office Equipment & Supplies
Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Nov 18, 2007 | Canon CanoScan N656U Flatbed Scanner
Canon CanoScan 4200F Flatbed Scanner Logo
69 people viewed this question
old marine
old marine
