Question about LG Studioworks 45 14" CRT Monitor
LG 500G CRT monitor horizontal transistor number
Horizontal transistor number
5 Suggested Answers
  • 20 Answers
SOURCE: Monitor LG 500G
open osd menu and recall. if not solve the problem .the change in circuit .horizontal output stage tr dv32v.this problem is horizontal mode stage .change the transitor .and chk capecitor
Posted on Nov 18, 2007
jemmyrash
  • 180 Answers
SOURCE: lg 500g crt monitor problem
Try checking B+ coil , may be the coil have shorted .
Happy trying
Posted on Apr 10, 2008
  • 4234 Answers
SOURCE: 2SC5589 in LG 17" CRT Monitor
This transistor is manufactured by Toshiba and is only available through Gateway.
Dan
Posted on May 07, 2008
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
Pincushion distortion of LG 500G CRT monitor, which parts is responsable for this.
hi,
You have to check the pin control transistor in the horizontal section. It will be fitted on the same heatsik on which the horizontal output transistor is fitted.It will be a small transistor as compaired to the horizontal driver. Also you have to check the three mosfets in this section used to control the width.
ok
Jul 31, 2011 | LG Studioworks 563N 15" CRT Monitor
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Horizontal screen size is too large all drivers are installed on winxp
This is Monitor Problem.you need an monitor service engineer.the problem is in Horizontal Deflection yoke/Horizontal output transistor section.
Nov 14, 2010 | LG Studioworks 563N 15" CRT Monitor
LG 17" 700E CRT MONITOR MOSFET 2N10 IS Immediately BURN OR SHORT WHEN SWITH ON THE MONITOR..
this might be the problem of the disk capacitor of value 2kv, which is located at the horizontal section, i.e from the collector of horizontal output transistor.
Aug 04, 2010 | LG 700M 17" CRT Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
INEED NO. OF OUTPUT HORIZONTAL LINE TRANSISTOR
If you mean 'flyback' or 'horizontal output transformer' and have the part number available, try one of the sources here:
Flyback links
If you do not have the number you may have to search Viewsonic's website to loacte it.
Warning; the number of suppliers for CRT monitor parts is shrinking rapidly, my best supplier, ICM in California is long gone.
Mar 31, 2009 | ViewSonic E70f 17" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
Lg 500g crt monitor problem
Happy trying
Apr 01, 2008 | LG Studioworks 45 14" CRT Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Monitor LG 500G
Nov 18, 2007 | LG L1915S 19" LCD Monitor
LG Studioworks 45 14" CRT Monitor Logo
27 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
