Question about Sharp AR-M207E Black and White Copier
"Sharp ar-m207" error code list - Sharp AR-M207E Black and White Copier
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
tehnik_bdg
  • 91 Answers
SOURCE: Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
Posted on Mar 04, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
My sharp AR-M207 is showing error H4.00 call for service i need solution
Enter simulation mode by pushing # * C * then type 14 and the copy button. The machine will restart and the error code will be gone.
Sep 26, 2011 | Sharp AR-M207 All-In-One Laser Printer
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
I have a Sharp AR-M207 with an H4-00 error. We have installed a new fuser but still get the error the moment that we turn on the device. I have seen several responses telling which buttons to press to...
heat roller low temperture detection&check the thermistor abnormality,heatlamp abnormality,thermostat abnormality,clean the paerdust guide &use sim 5-02
check the heater lamp blinking operation
use sim 14 to clear the slf diagnostic display
Oct 19, 2009 | Sharp AR-M207 All-In-One Laser Printer
No drivers Win Vista 64 -Sharp AR-M207 !!
Go to
  1. www.sharpusa.com
  2. Customer support tab
  3. product downloads
  4. product category (mfps and printer)
  5. model number (scroll to bottom and choose not listed)
  6. type in AR-M162
  7. Download type (driver)
  8. Search..... choose driver from below.
Sep 21, 2009 | Sharp AR-M207E Black and White Copier
Main code {22} ->
Sub code {07} ->
Jan 24, 2009 | Sharp AR-M237 Copier
SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Jan 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-M207E Black and White Copier Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
