Question about Bh Fitness TS1 Treadmill
What kind of lubricant fdo you use on treadmill decks
Lubricated deck now slippery to walk on
    New Friend:
  • 326 Answers
Silicone spray. Did you put it between the deck and the underside of the running belt? Not on the surface of the belt ( where you walk ) . if you put in on the top of the belt , then this is why it is slippery.
Posted on Dec 04, 2013
2 Suggested Answers
  • 52 Answers
SOURCE: treadmill is slippery after lubricating deck
You Ubricate it with silicon spray. It is usually bought at a sports shop which sell treadmills. You lift up the centre of the mat on both sides and give it a spray with silicon spray making sure it goes across the width of the deck. You only need to do one line across, not the whole of the deck. If you have used oil to do this then there lies your problem with the slipping issue. If no oil is used then the adjusters on the rollers which realign the mat may need to be tightened usually with an Allen key wrench, but make sure it is centralised, which you have to do while the machine is plugged in and running. Keep your fingers well clear of the let while any covers are removed as it will remove your finger as quick as a flash. Don't wear any trailing clothing either. Adjust at arms length. Good luck
Posted on Nov 24, 2013
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
How To Re-Wax a Wood Deck for a Trotter Treadmill
How To Re Wax Wood Trotter Treadmill Deck
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Apr 02, 2014 | Exercise & Fitness
Treadmill is slippery after lubricating deck
Nov 24, 2013 | Bh Fitness TS1 Treadmill
I have an IRONMAN 220T treadmill and have a code # E11 and I do not know what it mean, can anyone help me with this.
E11 Means that deck bel or walk belt is slower speed that speed window .
2 possible causes:a) Locked rotor from main motor b) High friction from deck or walk belt.
3) Use the calibration software from your equipment for easy diagnostic and correction.
4)Use the owner manual or your step under the Hood ,and proceed with the steps indicated.
5) You can lubricate the Deck or Walk belt. please see your owner manual section: Maintenance.http://www.youtube.com/watch?v=f7IZWMMrCM0 please see this videos for easy help in lubricating. and adjusting deck belt treadmill.
http://www.youtube.com/watch?v=AZSMLpXm-tA
sincerely. Merry Chrstmas.
ernesto cuadramanagua, nicaragua.c.a.
Dec 22, 2011 | Ironman 220t Programmable Treadmill (225...
Can walk on treadmill but soon as i start to run it stops
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current limiting curcuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 20, 2010 | Reebok Vista Treadmill - RBTL13305
Nordic Track treadmill trips GFI.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the GFI to trip. simple test start the treadmill do not walk on a see if the GFI is tripped in it does trip then lubricate, then if after lubricate it still the you have a worn belt and possibly damaged deck depending replacement price and on what you paid for the treadmill it may or may not be worth fixing.
May 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
It keeps shuting down
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
May 10, 2010 | Proform Crosswalk 500 Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Stops while in motion
May 01, 2010 | Proform CrossTrainer Treadmill
Where do i put lubricant in my reebok treadmill t5.1
To lubricate your treadmill, start by lifting the edge of the walking belt and spread the lubricant between the belt and deck. Once you have finished on one side, do the same to the other side. When you finished both sides, start the treadmill at around 3 mph. Then walk on the treadmill to spread the lubricant on the deck for about a minute. Then your done.
Apr 19, 2010 | Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Bh Fitness TS1 Treadmill Logo
124 people viewed this question
Top Bh Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Tom Chichester
Are you a Bh Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
