Question about Dryers
My dryer is new it's leaking water and not drying clothes it's bush tdv6w
The vent tube has water in also no instructions in box help!
    Sergeant:
  • 479 Answers
You have a plugged vent from the wall somewhere to where it goes to the outside , the way to tell is to unhook the vent hose run dryer through normal cycle and see if cloths dry
Posted on Nov 25, 2013
4 Suggested Answers
  • 184 Answers
SOURCE: Kenmore Elite H3 Dryer taking longer than normal to dry clothes
EVEN THOUGH THERE IS WARM AIR COMING OUT THE EXHAUST, IT STILL MAY HAVE A RESTRICTION IN THE DUCT WORK. DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER FOR ONE LOAD OF LAUNDRY. IF IT DRYS THE CLOTHES O.K., YOU HAVE A RESRICTION SOMEWHERE IN THE EXHAUST.
NOTE: DO NOT USE VINYL OR PLASTIC DUCTING. VINYL IS NOT U.L. APPROVED. PLASTIC PVC WILL ALLOW CONDENSATION TO PUDDLE INSIDE THE PIPE CAUSING A
COMPLETE RESTRICTION.
Posted on Mar 31, 2008
huuum
  • 750 Answers
SOURCE: Water collects under dryer. Clothes dry. floor wet. Vent open.
You said, Water collects under Clothes dry on floor.This sounds like a condenser dryer that needs the water retention bottle empdied or the hose to the bottle is leaking.
Check these two things
Huuum
Please leave a rating before you leave the site!
Posted on Feb 02, 2009
  • 2509 Answers
SOURCE: It doesnt dry the clothes, after 45 minutes they
It sounds like the fan isn't working properly (assuming all the ducting is clear).
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way.
Posted on Mar 04, 2011
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
Water coming out of the back of the dryer
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
Jan 13, 2015 | Maytag Neptune MAH5500B Front Load Washer
Water under and around dryer. Clothes dry but water on floor. The wash not leaking. I the vent and line are not clogged. What is causing the water under dry?
Unless the clothes are dripping, soaking, wet when they're put in the dryer (and it would take them a loooong time to dry if that were the case) there's bound to be a leak of some kind coming from somewhere other than the dryer. Do you have a lavatory or toilet on the other side of the wall behind the dryer? They dryer has no water of its own to leak.
Dec 27, 2011 | GE DBXR463EDWW Electric Dryer
Speed queen dryer takes twice as long to dry the clothes LGS27AWM3080 1003002387
disconnect vent tube and run a load of clothes, as it sounds like the vent tube is restricted. if that does not help then you will need to clean the dryer from the lint screen to the back of the dryers vent, where you hook up the vent tube. Hope this helped Tim
May 24, 2011 | Speed Queen AES17AWF Electric Dryer
My dryer seems to be heating up but the clothes take two cycles to dry.
sounds as if the vent is restricted, take vent tube off, dry a load of clothes. Clean vent tube, and you may want to clean the inside of the dryer,also. Hope this helps Tim
Apr 04, 2011 | Frigidaire Electric Dryer
Water under dryer after use. cleaned exhaust lint in it was wet. should i insulate exhaust tubing. fsminatrea@yahoo.com
Hi
Dryer would be either leaking from vent or due to condensation. The vent may either be blocked. The water is coming from the clothes you have dried in the dryer and it has no where to go.
You need to dismantle the vent and clean it, replace it with new vent. The dryer may now be consuming more time to dry the same load of clothes. By correcting the venting problem you will solve the water problem and shorten your wash day and save on electricity as well.
Another issue is condensation which usually appears on the dryer vent pipe colder climates. As the warm air from the dryer is vented to the outside, it must be protected from the cold temperatures outside. If your dryer vent pipe is not properly insulated, the air that is being vented out will turn into water when it comes into contact with the cold pipe outside. This results in condensation and dripping water. To resolve this, you must insulate your dryer vent pipe along its entire length. This will ensure that the hot air from the dryer does not undergo temperature fluctuations, and no water will leak into the vent pipe. Hope this helps... Please post back if you need more information.
Danile
Dec 27, 2010 | Maytag Dryers
Dryer runs fine does not dry proper run 2 or 3 times and still damp clothes vent was not clogged pl,ease help
this website is very helpful, I would disconnect vent tube and dry a load of clothes, if they dry then my vent tube is restricted or too long. If it does not then my dryer needs to be cleaned out on the inside from the lint trap down. I hope this helps Tim
http://www.applianceaid.com/general.html#vent
Nov 29, 2010 | Whirlpool WED5500S Electric Dryer
I have a dryer # 67832791 and doesn't seem like it heats up and takes longer to dry the clothes. Seems to run fine and operate fine just not drying the clothes.
restriction in the venting, disconnect vent tube, leave disconnected dry clothes and if they dry then clean out vent tube(vacuum, leaf blower, etc). Hope this helped Tim
Nov 28, 2010 | Kenmore Dryers
Dryer leaks when operating.
yep...condensation,,,cold air is coming back down the exhaust vent,,while hot moist are is trying to get out..onthejob,,no flap out side on vent...
Jan 03, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Noisy dryer not drying clothes, water found in vent tube
You either have a restriction somewhere in the venting which you say you have already checked or maybe a bad blower (fan). it may be stripped off the shaft and not pulling any air through the machine. If you run the dryer with the hose removed at the back and it dries well you have a problem with your venting. If it still takes three cycles it's a problem with the dryer. Repair would probably run about $100-150
Oct 13, 2008 | Dryers
Dryers Logo
130 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
