I turn on the desktop, I get a black screen with no beeps. the yellow light is also on in the front
I have tried removing the cmos battery, the ram, still nothing. I took the hard drive out, and put in another desktop I haven't booted to it yet, but I can see the windows files, and programs. they are recoverable
    Sergeant:
  • 275 Answers
It might be your power supply, let me know if you need more info
Posted on Nov 24, 2013
4 Suggested Answers
cheap to fix
  • 404 Answers
SOURCE: Computer Beeping, something loose?
looks like u've done most of the steps.
put everything how it was, change the ram to the next availble slot. remove power, remove bios battery "like a watch battery" wait 10min and put back on and power on see what happens
Posted on Mar 11, 2009
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
babes_ganda0
  • 381 Answers
SOURCE: I ahve an emachine T6524 and when you start it up
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
Posted on May 09, 2009
Acer m264 want boot up hdd no bios screen or anything
is there power coming?
if yes
remove the side cover and remove cmos battery and check if it is working, replace the battery
if that doesnt work remove the ram and check if it beeps
if it beeps replace the ram
May 20, 2014 | Acer Veriton M264-EC1200C Dual-Core E1200...
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Nov 24, 2013 | HP Pavilion Computers & Internet
MyGateway 560 GE desktop powers on but monitor is black it also beeps
How many beeps do you hear are they long beeps or short beeps ?
or long beeps and short beeps ?
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk, and remains active until turned off. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Test all power and data leads that attach from Motherboard to your Hard Drive SATA Make sure they have a secure dust free connections.
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it. Restart your computer the found new hardware wizard should activate.
Hope this helps.
Jan 04, 2013 | Computers & Internet
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
HP IQ 526 When I press the power button the backlights flash and the power led goes yellow after a few seconds the screen flashes again and the fans restart then it just stays dark, if I hold the power...
Hi Jerry,
Do follow the steps below...
1. Remove the RAM from the motherboard and switch it on. (you'll get 6 continuos beeps) Refix the RAM and check whether it is working or not...
2. Remove the CMOS battery and switch on the PC_ Switch off_Re fix the battery to the slot_Switch on...
3. Disconnect the hard disk from the PC and switch it on...
May 21, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
When I turn on my emachine, it beeps beeps beeps..... nothing on the monitor.....
Hi oleresi
If there is a continues beep sound then the RAM is corrupted or gone, you need to replace a new RAM
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | E-Machines D6417 (RBD6417) PC Desktop
Monitor light blinks but no pic when booted up
i can try to help you, do you hear the boot beep sound? if you are not able to hear the beep sound then i suggest you to open the machine and check with the cmos battery if it is working or no. if your cmos battery is working then have a check with Power supply. if the power supply working then there might be a problem with your motherboard or cpu. now let me talk about checking the ram. if you are able to remove the ram module remove it and see if u can hear a long beep sound if you are able to hear it try to clean the ram contacts with eraser and then try installing it. i think this might help you
Jun 09, 2009 | E-Machines eMachines Desktop PC
Error lights, Multiple beeps, no display.
Replace the CMOS battery and try again.  Maybe reseat the video card....
Nov 21, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
Mar 19, 2008 | HP Compaq Motherboard
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
