Question about Electrical Supplies
3Way Wiring Diagram
How to conect inside wires for fan and lights
  • 2,113 Answers
If you want to run the fan and light separately and the light is on a 3 way switch you will need 2 dimmers and one of them will be a 3 way dimmer. You need a 3 wire cable running up to the ceiling fan and the 3 way 3 wire cable coming from the one switch box to the other switch box. If it runs to the light first and then to the other switch box you would need to replace one of the 3 wire cables with a 4 wire or 5 wire cable. It's hard to find a wiring diagram for your situation unless you give a lot more details. If you can't explain what you have then this is complicated enough to have someone knowledgeable on site.
Posted on Nov 25, 2013
Fan blower wiring diagram for 1992 Buick Lasabre
CK THE CONECTION AT THE BLOWER MOTOR
Sep 02, 2014 | Cars & Trucks
Tip
4 way switch
If you wish to control a light or lights from more than 2 places, then you need a 4 way switch in between the 3way switches. You can use any number of 4 way switches in a lighting circuit.
To rough wire the switches, run a 3wire with ground cable from the 3way thru the 4way(s) to the other 3way. As in the 3way switch wiring the light and power can be at either end, that part does not change.
The diagram for the addition of a 4way switch looks like this..
The travelers from the 3way switch connect to like colored screws on the 4way .. If more switches are wanted, just add them in the center of the circuit in the same manner as the first 4way .
on May 14, 2010 | Hammering
Wiring diagram 1992 Buick Lasabre
CK CONECTION AT THE BLOWER MOTOR
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
3 ways wiring diagram
Are you asking about 3way wall light switches? ..
Please vote !!
May 09, 2010 | Linksys WAG200G Router
Wiring diagram for electricmotor with capacitor
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
May 09, 2010 | Heating & Cooling
Wiring a fan with two seperate switches
I am assuming that you have two 3way switches controlling this fan/light .. if there are more switches , then stop here and get back to me
connect the house wires red to red and black to black , then a house4 white to the ]fan white , the other house white connects to both the black and blue from the fan .. to be exactly correc the white fan wire should be connected to the white house wire that is the white power wire from the electrical panel.,
Jan 18, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Household wiring
There are 2 3way switches. Usually one end has a wire going to the light, and the other end 3 way switch has the always on power coming in. Between the two switches are 2-wire travellers.
On the actual 3way switches;
2 screws are the same color and the 2-wire travellers go on these. The other screw is a different color -usually black. This screw gets the power on one end, and the switch leg to the light at the other end.
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
384 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
