Question about Waring JEX 328 Health Juicer
Not Able to Use
The bowl or body is stuck and full of dried juice. Seems like a plastic part might have broken off. Any possibility of repair?
Pusher stuck in fusion juicer
May not be repairable if pusher is distorted or damaged. If jammed with a foreign body, need to carefully pry apart and clean out. Find a handy person and offer a fine juice meal.
Nov 25, 2014 | Juicers
How do i get the screen filter out of juicer
I had the same problem with my Salton juicer, after making a delicious juice it was almost impossible to remove the auger like many of you, with patience and lots of elbow grease I manage to take apart. Here is my solution to this problem and it works very well for me, its simple, before juicing, disassemble your juicer and add a little oil with your finger on the silicon seal (inside and outside) see picture attached, assemble the juicer.
After juicing, remove the cover, don't try removing the auger, instead grab the basket and wobble it and it should get free, it works for me and it should work for you too. Happy juicing to all!
May 20, 2014 | Salton JM411 Juiceman II Elite Juicer
I am trying to disassemble. I have done it many times, but the basket won't come off the base this time. I have poured hot soapy water through in forward and reverse. Not working
Many times when juicing very fibourous produce the bowl(basket) can get stuck and you can loosen it by gently tapping on the pulp spout or juice spout to the counter clockwise motion(right), this will loosen the bowl.
Aug 07, 2011 | Omega Juicers VRT330
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Feb 16, 2011 | Salton JM411 Juiceman II Elite Juicer
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
Jan 28, 2011 | Acme 6001 Juice Extractor
On the shaft that produce from the Juice Extractor
ONE ACME AND OMEGA IT'S CALLED THE
CLUTCH NUT. GOOGLE THE MFG. OR
FOR YOUR BRAND'S PARTS.
Jun 29, 2009 | Hamilton Beach Juicers
Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
TRY INVERTING IT AND SOAKING IN A
SOLUTION OF OXI CLEAN AND HOT WATER.
Jun 28, 2009 | Juicers
Broken bracket
Hi, I have the Acme 6001 Juicer and I love it! I would take the broken bracket and the juicer to a machine shop that does welding. Shouldn't cost more than a few bucks for them to spot weld the bracket back on. A good maching shop can fix this as they will have another bracket to reference the repair. hope this helps...gary One of our local shops can fix about anything and they are very reasonable and pretty quick.
Mar 10, 2009 | Acme 6001 Juice Extractor
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Tom
Jan 25, 2009 | Salton JM411 Juiceman II Elite Juicer
Rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Jul 15, 2008 | Juicers
Waring JEX 328 Health Juicer Logo
Top Waring Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Waring Juicer Expert? Answer questions, earn points and help others
