Question about Whirlpool GEW9250 Electric Dryer
Timer works, belt intack, i think it's the push to start
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
If the control looks like it has programmed but the dryer will not start, there is a thermal fuse down behind the lint filter housing. It is white and rectangular and has tow wires going to it. If it does not show continuity through it when tested with a meter, it will need to be replaced and is available below.
Thermal Fuse
Posted on Nov 25, 2013
My Kenmore Dryer just quit today. I have checked the breakers. They are ok.
Many possibilities. Door switch, start switch, timer, thermal fuse, motor, belt, or improper voltage I think mostly covers it.
Oct 12, 2017 | Kenmore Dryers
It stalled like the timing belt snap but its all intack just wont start
have the fault codes read
check for cam/crank position sensor problem
Aug 04, 2015 | 2004 Kia Rio
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Its a gas kenmore dryer 30 years old, I think its the timer. It sounds like it wants to start, it works everyother day. but not continuously. The serial number is M83006981, i dont think you make that...
Does not sound like a timer problem. Check to see if the belt is worn and slipping on the drive pulley and replace the belt if necessary.
Oct 16, 2009 | Dryers
No washing
it doesnt have a timer it has electronic board and panel odds are they both need replaced if less than 5 yrs but purchased before 2006 should have manufacture warranty still call your local maytag man
Mar 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool GEW9250 Electric Dryer Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
