Question about Refrigerators
Whirlpool water cooler b10p leaking - Refrigerators
Why is my whirlpool water cooler leaking
I really need more info about you problem....
Sep 27, 2014 | Water Filters & Coolers
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
Temperature on a whirlpool D10 watercooler
Lisa coolers similar to yours=> Whirlpool Dual-Temp Top-Loading Water Cooler
It appears that customers gave a not so good review yet being inexpensive this is common when most products are imported from China. The WHKM-D10 that you have now is now called the WHKM-10DP Whirlpool Dual-Temp Top-Loading Water Cooler with Heated Water. Wish I had better news, but please keep me in mind for any other Whirlpool, Maytag, Kitchenaid, Jenn-Air, Amana,or GE Home Appliances, Thanks, John Tripp/AKA Sea Breeze
http://appliance911seabreeze.com/
Whirlpool Factory Technician
You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
Nov 15, 2011 | Refrigerators
Water leaked into transmission and transmition oil into radiator
Your transmission cooler is cracked. Discontinue using that cooler immediately. Get some caps, cap off the cooler. Replace the cooler with an after unit vor about $80.00. Change the transmission fluid and engine coolant before you drive any further.
Sep 19, 2011 | 1996 Ford Explorer
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
My ice maker overflows
If the fill tube gets choked up with ice, it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut. or it could be that the ice maker is not level.
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Mar 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
