Question about HP Pavilion Computers & Internet
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
When I turn it on, it runs, but I hear no beeps, and the screen is black. also an orange light is on in the front
    Problem Solver:
  • 18 Answers
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Posted on Nov 24, 2013
  • 3940 Answers
SOURCE: computer does not boot
AAGG is an indication of a memory error, reseat memory modules, if no luck replace the RAM
Posted on Dec 11, 2008
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
  • 166 Answers
SOURCE: optiplex gx620 black screen stuck on safe mode
Look at the motherboard (mobo). Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything.
You could also try to change out the power supply if you can find another one that fits it.
Posted on Mar 11, 2009
WhoDoctorK9
  • 41 Answers
SOURCE: When I turn on my computer, I can hear the fan
The video on that particular system is integrated in the motherboard. With that being said, I would say that your motherboard is going out. It may have taken a hit from lightening and just did not kill it completely. It's a good looking computer, I would look into another motherboard that has the same specs that yours has. You can get a new motherboard for about $50 USD if you go to www.pricewatch.com and look under MOTHERBOARDS and then look for PROCESSOR TYPE and then ATHLON X2. Hope this helps you.
Posted on Mar 30, 2009
mailtoravi
  • 186 Answers
SOURCE: My computer is a dell
6 Beeps in your Studio XPS 8100 computer indicates Video Card failure.
The Motherboard is unable to detect the Video Card properly or not at all.
Try removing and re-seating the Video Card by following the instructions in the link which opens up the Service Manual of the computer:
http://support.dell.com/support/edocs/systems/studio8100/en/index.htm
If the computer still behaves the same way after removing and reseating the Video Card, you may have to get the Video Card replaced...check with Dell about the Warranty and if the computer is still covered under warranty, get the Video Card replaced.
However, if the computer is out of warranty, you can replace the Video Card in the computer with any one of these as per your choice:
ATI Radeon HD 5770
NVIDIA GeForce GTX 260
NVIDIA GeForce GTS 240
NVIDIA GeForce GT 220
Posted on Mar 23, 2011
I cant boot my computer
It is possible that the drive has failed, or the computers power supply has failed, or maybe the memory. Usually when a computer boots, you will hear a beep. if you hear more than the one beep, it will tell you what is causing the problem, let me know how many beeps you hear, if any.
Dec 26, 2014 | Dell OptiPlex 360 (BPCW3DR_1) PC Desktop
No beep, No display, Shuts off after ten seconds.
i suggest you take it to a computer specialist
Dec 28, 2013 | Dell OptiPlex GX150 PC Desktop
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
My packard bell ixtreme 5830 wont turn on. the light stays orange instead of green can anyone help
if it beeps there is a memory problem inside if not turn it on so its orange turn it a round and flip the the red switch on the back of the power suppy, multiple times and then start turning off the computer, ive got that to work it could just something dumb with the power supply
Jun 11, 2010 | Packard Bell ixtreme 9222 (P491000102) PC...
Pc turns on but screen says no signal
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
  • When the PC turn on there is any beep.
  • If no beep then your RAM is alright.
  • Problem in VGA Card.
Mar 15, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
When the computer is plugged in it doesnt work. The datech fan doesnt work. The front of the computer displays an orange light instead of green. If I replace the fan will this correct the problem
Replacing the fan as far as I know should not cause a light change but instead the computer would get hot shutdown every time he got too warm the orange light usually signifies a hardware problem. If you have opened your computer before you might have accidentally disconnected the hard drive or one of the cables from the motherboard. If the hard drive is disconnected that usually will get an orange light or if a ram chip is missing or not in all the way does a computer beep when you turn it on
Jul 27, 2009 | Dell Dimension 3000 PC Desktop
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
Lights 3 &4 stay on.
Computer beeping at you is usually a problem with the video card or memory. Try re-seating both and see if you still have the same problem. If you do, individually remove each component and power on to test if the beeps persist.
Jan 06, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
59 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
