Question about Unknown Heat Surge Amish Crafted Roll-n-Glow Electric Fireplace Dark Oak Refurbished
My electric fireplace is beeping and wont turn on
Beeping sound, blinking red light, wont turn on
  • Barb Herl Nov 24, 2013
    unplugged for 30 minutes, then it worked!!!!!
Furnace blinking red light
makes squeeling only when furnace starts to turn self on
Dec 17, 2013 | Safety First Humidifiers
Both hi and lo light flashing, unit will not go on (used twice)
I have 3 exact units of the SWM5750DN-WM also and after cleaning them and put away for the summer (used in Winter 2016), and taking them out now (Oct 2017) for use, and all 3 are blinking green lights! The manual doesn't even list the blinking lights as a troubleshooting info... This sounds like a common occurrence so you'd think Sunbeam should have that readily available!
Anybody have a solution? I can't believe they are this fragile??
Feb 20, 2013 | Sunbeam Warm Mist Humidifier, SWM5750DN-WM
Service light on Honeywell humidifier
Sounds like a Water Level Sensor problem. Read the service manual, pages 51 and 53.
http://www.forwardthinking.honeywell.com/related_links/humidification/69_2285.pdf
Unplug the power cord. Turn OFF water. Remove the Water Level Sensor - One screw holds down the spring clip. Remove water scale in the compartment and on the Sensor. Test Sensor with an ohm meter. If OK, reassemble and try again. If bad, replace the sensor.
If you have heavy scale buildup in the sensor compartment, you need better water filtration. Your problems are just starting. This system can be very difficult to clean thoroughly.
Nov 15, 2012 | Honeywell Truesteam HM512W1005...
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
It ran out of water and the red light came on and now it won't work anymore. i put in new water, but the red light won't turn off. Any way to fix it?
Probably the float. The manual has instructions for fixing it: http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Jun 12, 2010 | Crane Penguin 1 Gallon Humidifier
Change water pad but change water panel light is on
Turn the control knob to the
“Test/Reset” position until the “Change
Water Panel” light blinks to reset the
water panel change indicator timer.
(Blower must be operating and furnace
calling for heat.) Be sure to turn the
control knob back to the prior setting when finished
Oct 27, 2009 | Aprilaire 700 Humidifier
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Got it on Craigslist
The red light indicates that there is no water in it. You need to put water in it, then a green light comes on instead. When the water runs out you will see the light turn red again. You need to fill it about 2/3 - 3/4 of the way up to make it last.  You should refill it about once a day or every 2 days depending on how often you use it. But when you see the red light on then you know the water is gone.
May 03, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Unknown Heat Surge Amish Crafted Roll-n-Glow Electric Fireplace Dark Oak Refurbished Logo
222 people viewed this question
Top Unknown Humidifiers Experts
Paul Carew
Dennis
Are you an Unknown Humidifier Expert? Answer questions, earn points and help others
