Question about Honeywell Programmable Thermostat Heater
CALIBRATE THERMOSTATIC HEAT CONTROL
MATCH ROOM TEMPERATURE TO THERMOSTAT READING
  • 39 Answers
Honeywell part number is needed to determin which procedure to use.
Posted on Dec 12, 2013
I have an Observer Thermostat that's about 1 yr old. It's reading 5 degrees higher than 2 different digital thermometers. Is there a way to calibrate these things?
There is no way to calibrate the thermostat. It is set at the factory with an accuracy range of 2 to 3 degrees. It also can be the location of the thermostat. Even the wall it is mounted on can contribute to heat range. It is also measuring the ambient temperature in the room, which can vary depending on the contents of the room. If it aint broke, don't fix it. It is getting too cold to fiddle with the thermostat.
Dec 12, 2017 | Ovens
I have a 9610 thermostat turns on and off to frequently
I am guessing but the thermostat is either faulty or is in conflict with another thermostatic device in the system. The room thermostat measures the air temperature in the room but with a modern intelligent boiler there will be other sensors measuring all sorts of things including the water temperature.
Personally I prefer to have thermostatic radiator valves rather than a room or zone thermostat.
Jan 02, 2017 | Heating & Cooling
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
Honeywell HZ-338 thermostat problem
See if there is a little brass-looking bulb on a wire (sensing bulb) inside that can be moved away from the heat. My other thought would be maybe there is supposed to be some insulation between the control unit and the heating element that was inadvertently discarded?
Nov 27, 2013 | Honeywell HZ-338 Ceramic Compact Heater
The dryer lights, heats up for a few minutes then the heat shuts off
your limit thermostat is going out heres how to check them
The wires leading to the thermostat are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. I strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Maytag MDG16MN Gas Dryer
The motor turns but the heat is lower than before. Model no NE 5313-4562
check the thermostats ,, you have a high limit thermostat thats probably on its way out , heres how to check them
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermostat should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. strongly recommend that you test your thermostat at room temperature.
Jul 13, 2011 | Speed Queen Dryers
How do i test my room thermostat
To check your thermostat you need to advance the temperature towards the setpoint slowly. You also need an acurate thermometer to see if the thermostat will turn the heat or A/C on when the setpoint is reached. Also check the make sure that the temperature on the thermostat is close to the reading on your thermostat.
Heatman101
Feb 27, 2010 | Kitchen Appliances - Others
Thermostat sensor is not reading correctly
No you need to change your t,stat. Go to home depot or Lowes and get one easy to install Any problems please get back to me I will walk you thru. Rus
Oct 29, 2009 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH7400D
The thermostat will not cut off the A/C until the thermometer reading gets to 76.
If there is not a heat source near/behind the thermostat which is causing the thermometer to read higher than actual room temperature, it sounds like the thermostat thermometer is out of calibration.
There are ways to calibrate it, but much to involved to go into here.
One solution is to just set the thermostat at 80, knowing that it's really set on 76.
Another solution is to replace the thermostat.
Charlie
Aug 14, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
112 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
