What are sticky keys - Computers & Internet
  • 20 Answers
It is when you press your SHIFT key 5 or multiple times. Because some applications may require this option that why they need to enable it.
Posted on Nov 27, 2013
Re: Microsoft wired 600 keyboard/sticky keys... Wanting to know how do I enable sticky keys on my Microsoft wired 600 keyboard pls?
Sticky Keys is a software function. I am assuming you are using Windows - open the Control Panel, select the Ease of Use Center, select Make the keyboard easier to use. In here, you can turn on and setup Sticky Keys.
Dec 21, 2016 | Microsoft Computers & Internet
Shift key is not working
You might consider using, at least tempory, a external usb keyboard with a touchpad, you can get get them at Wal-Mart for around $20.00
Otherwise consider taking it to a computer shop and have them test the keyboard and if need be order you a new one. If this computer is still under warranty then I would would talk to the support team that you purchase it from. Good Luck.
Mar 28, 2014 | Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Rgds,
Divya
Sep 02, 2012 | HP (395366-001) Keyboard
What are sticky keys My shift will not work and I keep getting a message about sticky keys
Hi
Please try to press both the shift keys at the same time
this may disable the sticky keys and return the keyboard to normal
this quite often happens when you hold the shift key down for longer than 8 seconds or more
many thanks
Aug 16, 2011 | Computers & Internet
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
How to turn off explorer sticky keys
In the Control Panel (Classic View), open the Ease of Access Center control panel. Follow the link that says, "Make the keyboard easier to use." Uncheck the box that says "Turn on Sticky Keys." You can also follow the "Set up Sticky Keys" link to adjust the Sticky Keys options.
Hope this helps!
Mar 10, 2011 | Microsoft Windows Vista Home Basic Edition...
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
Both shift keys not working in my laptop
WEl Bro I Read Your Problem ITs A Very Complicated Isse So I have a Easy Solution For It The Solution is that Put Your Key BOard in Water OR Through From the Window OR Put it Into Your Dusbin :D
Jun 29, 2009 | Compaq Keyboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
